System Administration Guide: Network Services
NFS Troubleshooting Procedures
To determine where the NFS service has failed, you need to follow several procedures to isolate the failure. Check for the following items:
In the process of checking these items, you might notice that other portions of the network are not functioning. For example, the name service or the physical network hardware might not be functioning. The System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP) contains debugging procedures for several name services. Also, during the process you might see that the problem is not at the client end. An example is if you get at least one trouble call from every subnet in your work area. In this situation, you should assume that the problem is the server or the network hardware near the server. So, you should start the debugging process at the server, not at the client.
ProcedureHow to Check Connectivity on an NFS Client
  1. Check that the NFS server is reachable from the client. On the client, type the following command.
    % /usr/sbin/ping bee
    bee is alive
    If the command reports that the server is alive, remotely check the NFS server. See How to Check the NFS Server Remotely.
  2. If the server is not reachable from the client, ensure that the local name service is running.
    For NIS+ clients, type the following:
    % /usr/lib/nis/nisping -u
    Last updates for directory eng.acme.com. :
    Master server is eng-master.acme.com.
            Last update occurred at Mon Jun  5 11:16:10 1995
    Replica server is eng1-replica-58.acme.com.
            Last Update seen was Mon Jun  5 11:16:10 1995
  3. If the name service is running, ensure that the client has received the correct host information by typing the following:
    % /usr/bin/getent hosts bee
    129.144.83.117	bee.eng.acme.com
  4. If the host information is correct, but the server is not reachable from the client, run the ping command from another client.
    If the command run from a second client fails, see How to Verify the NFS Service on the Server.
  5. If the server is reachable from the second client, use ping to check connectivity of the first client to other systems on the local net.
    If this command fails, check the networking software configuration on the client, for example, /etc/netmasks and /etc/nsswitch.conf.
  6. (Optional) Check the output of the rpcinfo command.
    If the rpcinfo command does not display program 100003 version 4 ready and waiting, then NFS version 4 is not enabled on the server. See Table 5–3 for information about enabling NFS version 4.
  7. If the software is correct, check the networking hardware.
    Try to move the client onto a second net drop.
ProcedureHow to Check the NFS Server Remotely
Note that support for both the UDP and the MOUNT protocols is not necessary if you are using an NFS version 4 server.
  1. Check that the NFS services have started on the NFS server by typing the following command:
    % rpcinfo -s bee|egrep 'nfs|mountd'
     100003  3,2    tcp,udp,tcp6,upd6                nfs     superuser
     100005  3,2,1  ticots,ticotsord,tcp,tcp6,ticlts,udp,upd6  mountd  superuser
    If the daemons have not been started, see How to Restart NFS Services.
  2. Check that the server's nfsd processes are responding.
    On the client, type the following command to test the UDP NFS connections from the server.
    % /usr/bin/rpcinfo -u bee nfs
    program 100003 version 2 ready and waiting
    program 100003 version 3 ready and waiting
    Note –
    NFS version 4 does not support UDP.
    If the server is running, it prints a list of program and version numbers. Using the -t option tests the TCP connection. If this command fails, proceed to How to Verify the NFS Service on the Server.
  3. Check that the server's mountd is responding, by typing the following command.
    % /usr/bin/rpcinfo -u bee mountd
    program 100005 version 1 ready and waiting
    program 100005 version 2 ready and waiting
    program 100005 version 3 ready and waiting
    If the server is running, it prints a list of program and version numbers that are associated with the UDP protocol. Using the -t option tests the TCP connection. If either attempt fails, proceed to How to Verify the NFS Service on the Server.
  4. Check the local autofs service if it is being used:
    % cd /net/wasp
    Choose a /net or /home mount point that you know should work properly. If this command fails, then as root on the client, type the following to restart the autofs service:
    # svcadm restart system/filesystem/autofs
  5. Verify that file system is shared as expected on the server.
    % /usr/sbin/showmount -e bee
    /usr/src										eng
    /export/share/man						(everyone)
    Check the entry on the server and the local mount entry for errors. Also, check the namespace. In this instance, if the first client is not in the eng netgroup, that client cannot mount the /usr/src file system.
    Check all entries that include mounting information in all the local files. The list includes /etc/vfstab and all the /etc/auto_* files.
ProcedureHow to Verify the NFS Service on the Server
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Check that the server can reach the clients.
    # ping lilac
    lilac is alive
  3. If the client is not reachable from the server, ensure that the local name service is running.
  4. If the name service is running, check the networking software configuration on the server, for example, /etc/netmasks and /etc/nsswitch.conf.
  5. Type the following command to check whether the rpcbind daemon is running.
    # /usr/bin/rpcinfo -u localhost rpcbind
    program 100000 version 1 ready and waiting
    program 100000 version 2 ready and waiting
    program 100000 version 3 ready and waiting
    If the server is running, it prints a list of program and version numbers that are associated with the UDP protocol. If rpcbind seems to be hung, reboot the server.
  6. Type the following command to check whether the nfsd daemon is running.
    # rpcinfo -u localhost nfs
    # ps -ef | grep nfsd
    root    232      1  0  Apr 07     ?     0:01 /usr/lib/nfs/nfsd -a 16
    root   3127   2462  1  09:32:57  pts/3  0:00 grep nfsd
    Note –
    If the server is running, it prints a list of program and version numbers that are associated with the UDP protocol. Also use the -t option with rpcinfo to check the TCP connection. If these commands fail, restart the NFS service. See How to Restart NFS Services.
  7. Type the following command to check whether the mountd daemon is running.
    # /usr/bin/rpcinfo -u localhost mountd
    # ps -ef | grep mountd
    root    145      1 0 Apr 07  ?     21:57 /usr/lib/autofs/automountd
    root    234      1 0 Apr 07  ?     0:04  /usr/lib/nfs/mountd
    root   3084 2462 1 09:30:20 pts/3  0:00  grep mountd
ProcedureHow to Restart NFS Services
  2. Restart the NFS service on the server.
    Type the following command.
    # svcadm restart network/nfs/server
Identifying Which Host Is Providing NFS File Service
Run the nfsstat command with the -m option to gather current NFS information. The name of the current server is printed after “currserver=”.
% nfsstat -m
/usr/local from bee,wasp:/export/share/local
 Flags: vers=3,proto=tcp,sec=sys,hard,intr,llock,link,synlink,
		acl,rsize=32768,wsize=32678,retrans=5
 Failover: noresponse=0, failover=0, remap=0, currserver=bee
ProcedureHow to Verify Options Used With the mount Command
In the Solaris 2.6 release and in any versions of the mount command that were patched after the 2.6 release, no warning is issued for invalid options. The following procedure helps determine whether the options that were supplied either on the command line or through /etc/vfstab were valid.
For this example, assume that the following command has been run:
# mount -F nfs -o ro,vers=2 bee:/export/share/local /mnt
  1. Verify the options by running the following command.
    % nfsstat -m
    /mnt from bee:/export/share/local
    Flags:  vers=2,proto=tcp,sec=sys,hard,intr,dynamic,acl,rsize=8192,wsize=8192,
            retrans=5
    The file system from bee has been mounted with the protocol version set to 2. Unfortunately, the nfsstat command does not display information about all of the options. However, using the nfsstat command is the most accurate way to verify the options.
  2. Check the entry in /etc/mnttab.
    The mount command does not allow invalid options to be added to the mount table. Therefore, verify that the options that are listed in the file match those options that are listed on the command line. In this way, you can check those options that are not reported by the nfsstat command.
    # grep bee /etc/mnttab
    bee:/export/share/local /mnt nfs	ro,vers=2,dev=2b0005e 859934818
