System Administration Guide: Network Services
ProcedureHow to Check Connectivity on an NFS Client
  1. Check that the NFS server is reachable from the client. On the client, type the following command.
    % /usr/sbin/ping bee
    bee is alive
    If the command reports that the server is alive, remotely check the NFS server. See How to Check the NFS Server Remotely.
  2. If the server is not reachable from the client, ensure that the local name service is running.
    For NIS+ clients, type the following:
    % /usr/lib/nis/nisping -u
    Last updates for directory :
    Master server is
            Last update occurred at Mon Jun  5 11:16:10 1995
    Replica server is
            Last Update seen was Mon Jun  5 11:16:10 1995
  3. If the name service is running, ensure that the client has received the correct host information by typing the following:
    % /usr/bin/getent hosts bee
  4. If the host information is correct, but the server is not reachable from the client, run the ping command from another client.
    If the command run from a second client fails, see How to Verify the NFS Service on the Server.
  5. If the server is reachable from the second client, use ping to check connectivity of the first client to other systems on the local net.
    If this command fails, check the networking software configuration on the client, for example, /etc/netmasks and /etc/nsswitch.conf.
  6. (Optional) Check the output of the rpcinfo command.
    If the rpcinfo command does not display program 100003 version 4 ready and waiting, then NFS version 4 is not enabled on the server. See Table 5–3 for information about enabling NFS version 4.
  7. If the software is correct, check the networking hardware.
    Try to move the client onto a second net drop.
