System Administration Guide: Network Services
ProcedureHow to Use the /etc/default/autofs File
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Add or modify an entry in the /etc/default/autofs file.
    For example, if you want to turn off browsing for all autofs mount points, you could add the following line.
    AUTOMOUNTD_NOBROWSE=ON
    This keyword is the equivalent of the -n argument for automountd. For a list of keywords, refer to /etc/default/autofs File.
  3. Restart the autofs daemon.
    Type the following command:
    # svcadm restart system/filesystem/autofs
