System Administration Guide: Network Services
Task Map for Autofs Administration
The following table provides a description and a pointer to many of the tasks that are related to autofs.
Table 5–5 Task Map for Autofs Administration
Task
Description
For Instructions
Start autofs
Start the automount service without having to reboot the system
How to Start the Automounter
Stop autofs
Stop the automount service without disabling other network services
How to Stop the Automounter
Configure your autofs environment by using the /etc/default/autofs file
Assign values to keywords in the /etc/default/autofs file
Using the /etc/default/autofs File to Configure Your autofs Environment
Access file systems by using autofs
Access file systems by using the automount service
Mounting With the Automounter
Modify the autofs maps
Steps to modify the master map, which should be used to list other maps
How to Modify the Master Map
Steps to modify an indirect map, which should be used for most maps
How to Modify Indirect Maps
Steps to modify a direct map, which should be used when a direct association between a mount point on a client and a server is required
How to Modify Direct Maps
Modify the autofs maps to access non-NFS file systems
Steps to set up an autofs map with an entry for a CD-ROM application
How to Access CD-ROM Applications With Autofs
Steps to set up an autofs map with an entry for a PC-DOS diskette
How to Access PC-DOS Data Diskettes With Autofs
Steps to use autofs to access a CacheFS file system
How to Access NFS File Systems by Using CacheFS
Using /home
Example of how to set up a common /home map
Setting Up a Common View of /home
Steps to set up a /home map that refers to multiple file systems
How to Set Up /home With Multiple Home Directory File Systems
Using a new autofs mount point
Steps to set up a project-related autofs map
How to Consolidate Project-Related Files Under /ws
Steps to set up an autofs map that supports different client architectures
How to Set Up Different Architectures to Access a Shared Namespace
Steps to set up an autofs map that supports different operating systems
How to Support Incompatible Client Operating System Versions
Replicate file systems with autofs
Provide access to file systems that fail over
How to Replicate Shared Files Across Several Servers
Using security restrictions with autofs
Provide access to file systems while restricting remote root access to the files
How to Apply Autofs Security Restrictions
Using a public file handle with autofs
Force use of the public file handle when mounting a file system
How to Use a Public File Handle With Autofs
Using an NFS URL with autofs
Add an NFS URL so that the automounter can use it
How to Use NFS URLs With Autofs
Disable autofs browsability
Steps to disable browsability so that autofs mount points are not automatically populated on a single client
How to Completely Disable Autofs Browsability on a Single NFS Client
Steps to disable browsability so that autofs mount points are not automatically populated on all clients
How to Disable Autofs Browsability for All Clients
Steps to disable browsability so that a specific autofs mount point is not automatically populated on a client
How to Disable Autofs Browsability on a Selected File System
