System Administration Guide: Network Services
ProcedureHow to Select Different Versions of NFS on a Client by Modifying the /etc/default/nfs File
The following procedure shows you how to control which version of NFS is used on the client by modifying the /etc/default/nfs file. If you prefer to use the command line, refer to How to Use the Command Line to Select Different Versions of NFS on a Client.
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Edit the /etc/default/nfs file.
    For example, if you want only version 3 on the client, set the values for both NFS_CLIENT_VERSMAX and NFS_CLIENT_VERSMIN to 3. For a list of keywords and their values, refer to Keywords for the /etc/default/nfs File.
    NFS_CLIENT_VERSMAX=value
    NFS_CLIENT_VERSMIN=value
    value
    Provide the version number.
    Note –
    By default, these lines are commented. Remember to remove the pound (#) sign, also.
  3. Mount NFS on the client.
    Type the following command:
    # mount server-name:/share-point /local-dir
    server-name
    Provide the name of the server.
    /share-point
    Provide the path of the remote directory to be shared.
    /local-dir
    Provide the path of the local mount point.
See Also
Version Negotiation in NFS
