System Administration Guide: Network Services
Ampersand (&)
If you have a map with many subdirectories specified, as in the following, consider using string substitutions.
john        willow:/home/john
mary        willow:/home/mary
joe         willow:/home/joe
able        pine:/export/able
baker       peach:/export/baker
You can use the ampersand character (&) to substitute the key wherever the key appears. If you use the ampersand, the previous map changes to the following:
john        willow:/home/&
mary        willow:/home/&
joe         willow:/home/&
able        pine:/export/&
baker       peach:/export/&
You could also use key substitutions in a direct map, in situations such as the following:
/usr/man						willow,cedar,poplar:/usr/man
You can also simplify the entry further as follows:
/usr/man						willow,cedar,poplar:&
Notice that the ampersand substitution uses the whole key string. Therefore, if the key in a direct map starts with a / (as it should), the slash is included in the substitution. Consequently, for example, you could not do the following:
/progs				&1,&2,&3:/export/src/progs
The reason is that autofs would interpret the example as the following:
/progs 				/progs1,/progs2,/progs3:/export/src/progs
