Use this command to mount all file systems or a specific group of file systems that are listed in a file-system table. The command provides a way of doing the following:
Selecting the file-system type to be accessed with the -F FSType option
Selecting all the remote file systems that are listed in a file-system table with the -r option
Because all file systems that are labeled as NFS file-system type are remote file systems, some of these options are redundant. For more information, see the mountall(1M) man page.
Note that the following two examples of user input are equivalent:
# mountall -F nfs |
# mountall -F nfs -r |
