System Administration Guide: Network Services
UUCP/etc/uucp/Grades File
The /etc/uucp/Grades file contains the definitions for the job grades that can be used to queue jobs to a remote computer. This file also contains the permissions for each job grade. Each entry in this file represents a definition of an administrator-defined job grade that lets users queue jobs.
Each entry in the Grades file has the following format:
User-job-grade System-job-grade Job-size Permit-type ID-list
Each entry contains fields that are separated by a blank space. The last field in the entry is composed of subfields that are also separated by spaces. If an entry occupies more than one physical line, you can use a backslash to continue the entry onto the following line. Comment lines begin with a pound sign (#) and occupy the entire line. Blank lines are always ignored.
UUCP User-job-grade Field
This field contains an administrator-defined user-job-grade name of up to 64 characters.
UUCP System-job-grade Field
This field contains a single-character job grade to which User-job-grade is mapped. The valid list of characters is A–Z, a–z, with A having the highest priority and z the lowest.
Relationship Between User and System Job Grades
The user job grade can be bound to more than one system job grade. Note that the Grades file is searched sequentially for occurrences of a user job grade. Therefore, any multiple occurrences of a system job grade should be listed in compliance with the restriction on the maximum job size.
While no maximum number exists for the user job grades, the maximum number of system job grades that are allowed is 52. The reason is that more than one User-job-grade can be mapped to a System-job-grade, but each User-job-grade must be on a separate line in the file. Here is an example:
mail N Any User Any netnews N Any User Any
If this configuration is in a Grades file, these two User-job-grade fields share the same System-job-grade. Because the permissions for a Job-grade are associated with a User-job-grade and not a System-job-grade, two User-job-grades can share the same System-job-grades and have two different sets of permissions.
Default Grade
You can define the binding of a default User-job-grade to a system job grade. You must use the keyword default as the user job grade in the User-job-grade field of the Grades file and the system job grade that it is bound to. The Restrictions and ID fields should be defined as Any so that any user and any size job can be queued to this grade. Here is an example:
default a Any User Any
If you do not define the default user job grade, the built-in default grade Z is used. Because the restriction field default is Any, multiple occurrences of the default grade are not checked.
UUCP Job-size Field
This field specifies the maximum job size that can be entered in the queue. Job-size is measured in bytes and can be a list of the options that are described in the following list.
Integer that specifies the maximum job size for this job grade
Decimal number that represents the number of kilobytes (K is an abbreviation for kilobyte)
Decimal number that represents the number of megabytes (M is an abbreviation for megabyte)
Keyword that specifies that no maximum job size exists
Here are some examples:
UUCP Permit-type Field
This field contains a keyword that denotes how to interpret the ID list. The following table lists the keywords and their meanings.
Table 26–5 Permit-type Field
ID List Contents
Login names of users who are permitted to use this job grade
Login names of users who are not permitted to use this job grade
Group names whose members are permitted to use this group
Group names whose members are not permitted to use this job grade
UUCP ID-list Field
This field contains a list of login names or group names that are to be permitted or denied queuing to this job grade. The list of names are separated by a blank space and terminated by a newline character. The keyword Any is used to denote that anyone is permitted to queue to this job grade.
