System Administration Guide: Network Services
UUCP System-job-grade Field
This field contains a single-character job grade to which User-job-grade is mapped. The valid list of characters is A–Z, a–z, with A having the highest priority and z the lowest.
Relationship Between User and System Job Grades
The user job grade can be bound to more than one system job grade. Note that the Grades file is searched sequentially for occurrences of a user job grade. Therefore, any multiple occurrences of a system job grade should be listed in compliance with the restriction on the maximum job size.
While no maximum number exists for the user job grades, the maximum number of system job grades that are allowed is 52. The reason is that more than one User-job-grade can be mapped to a System-job-grade, but each User-job-grade must be on a separate line in the file. Here is an example:
mail N Any User Any netnews N Any User Any
If this configuration is in a Grades file, these two User-job-grade fields share the same System-job-grade. Because the permissions for a Job-grade are associated with a User-job-grade and not a System-job-grade, two User-job-grades can share the same System-job-grades and have two different sets of permissions.
Default Grade
You can define the binding of a default User-job-grade to a system job grade. You must use the keyword default as the user job grade in the User-job-grade field of the Grades file and the system job grade that it is bound to. The Restrictions and ID fields should be defined as Any so that any user and any size job can be queued to this grade. Here is an example:
default a Any User Any
If you do not define the default user job grade, the built-in default grade Z is used. Because the restriction field default is Any, multiple occurrences of the default grade are not checked.
