If you cannot contact a particular machine, you can check communications to that machine with Uutry and uucp.
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
# /usr/lib/uucp/Uutry -r machine |
Replace machine with the host name of the machine you are unable to contact. This command does the following:
Starts the transfer daemon (uucico) with debugging. You can get more debugging information if you are root.
Directs the debugging output to /tmp/machine.
Prints the debugging output to your terminal by issuing the following command:
# tail -f |
Press Control-C to end output. You can copy the output from /tmp/machine if you want to save the output.
If Uutry does not isolate the problem, try to queue a job:
# uucp -r file machine\!/dir/file |
Use the name of the file that you want to transfer.
Use the name of the machine that you want to copy to.
Specify the location of the file for the other machine.
Issue the following command:
# Uutry |
If you still cannot solve the problem, you might need to call your local support representative. Save the debugging output, which can help diagnose the problem.
You might also decrease or increase the level of debugging that is provided by Uutry through the -x n option. n indicates the debug level. The default debug level for Uutry is 5.
Debug level 3 provides basic information about when and how the connection is established, but not much information about the transmission. Debug level 9, however, provides exhaustive information about the transmission process. Be aware that debugging occurs at both ends of the transmission. If you intend to use a level higher than 5 on a moderately large text, contact the other site's administrator and decide when to change the level.
