System Administration Guide: Network Services
Chapter 28 Administering the FTP Server (Tasks)
This chapter includes tasks that are described in the following table to set up and administer an FTP server.
Administering the FTP Server (Task Map)
Table 28–1 Task Map: Administering the FTP Server
Task
Description
For Instructions
Configure access to the FTP server
Use the ftpaccess, ftpusers, and the ftphosts files in the /etc/ftpd directory to establish or restrict access to the FTP server.
How to Set User Login Limits
How to Control the Number of Invalid Login Attempts
How to Disallow FTP Server Access to Particular Users
How to Restrict Access to the Default FTP Server
How to Define FTP Server Classes
Set up FTP server logins
Establish login accounts for real, guest and anonymous users.
How to Set Up Real FTP Users
How to Set Up Guest FTP Users
How to Set Up Anonymous FTP Users
How to Create the /etc/shells file
Customize message files
Edit the /etc/ftpd/ftpaccess file to configure the FTP server to return messages to the FTP client related to specific events.
How to Customize Message Files
How to Create Messages to Be Sent to Users
How to Configure the README Option
Configure access to files on the FTP server
Use the /etc/ftpd/ftpaccess file to specify classes of users who are allowed to execute certain commands or to download and upload files to the FTP server.
How to Configure DA Discovery for Dial-up Networks
Controlling Uploads and Downloads on the FTP Server
Enable limited or complete virtual hosting
Use the /etc/ftpd/ftpaccess file to configure the FTP server to support multiple domains on the same machine.
How to Enable Limited Virtual Hosting
How to Enable Complete Virtual Hosting
Start the FTP server
Change the service properties to start the FTP server in nowait, standalone mode or foreground mode.
How to Start an FTP Server Using SMF
How to Start a Standalone FTP Server in the Background
How to Start a Standalone FTP Server in the Foreground
Shut down the FTP server
Use the /etc/ftpd/ftpaccess file and run the ftpshut to shut down the FTP server.
Shutting Down the FTP Server
Troubleshoot some common FTP server problems
Check syslogd and use greeting text and log commands to debug problems on the FTP server.
How to Check syslogd for FTP Server Messages
How to Use greeting text to Verify ftpaccess
How to Check the Commands Executed by FTP Users
Controlling FTP Server Access
You can use the following configuration files in the /etc/ftpd directory to control access to the FTP server.
ProcedureHow to Define FTP Server Classes
To log in to the FTP server, users must be members of a class when the ftpaccess file is used. To add the class directive to the ftpaccess file, you specify the class name, typelist of users who are permitted access from a particular host.
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Add entries for anonymous, guest, and real users in the ftpaccess file.
    class class typelist addrglob[addrglob...]
    class
    Keyword that is used to define FTP users.
    class
    A name that is defined by the class keyword. Each login is compared against a list of defined classes. The logged in user is considered a member of the first class matched.
    typelist
    A comma-separated list of the keywords that match the three types of users: anonymous, guest, and real.
    addrglob
    A globbed domain name or a globbed numeric address. The addrglob can also be the name of a file, starting with a slash (`/`), which contains additional address globs: address:netmask or address/cidr.
    Here are some examples of globbed addresses:
    • Numeric IPv4 address: 10.1.2.3
    • Globbed domain name *.provider.com
    • Globbed numeric IPv4 address 10.1.2.*
    • Numeric IPv4 address:netmask 10.1.2.0:255.255.255.0
    • Numeric IPv4 address/CIDR 10.1.2.0/24
    • Numeric IPv6 address: 2000::56:789:21ff:fe8f:ba98
    • Numeric IPv6 address/CIDR: 2000::56:789:21ff:fe8f:ba98/120
Example 28–1 Defining FTP Server Classes
class  local  real,guest,anonymous *.provider.com
class  remote real,guest,anonymous *
The previous example defines the local class as any user of the type real, guest, or anonymous who logs in from *.provider.com. The last line defines remote as any user who logs in from anywhere other than *.provider.com.
ProcedureHow to Set User Login Limits
You can limit the number of simultaneous logins by users of a certain class with directives that are set in the ftpaccess file. Each login limit contains the name of a class, a UUCP-style days-of-week list, and a message file to display if the limit is exceeded.
To set user login limits, follow the steps in the next procedure.
  2. Add the following entries to the ftpaccess file:
    limit class n times [message-file]
    limit
    Keyword that is used to restrict simultaneous logins by the specified number of users of a defined class at certain connection times.
    class
    A name that is defined by the class keyword. Each login is compared against a list of defined classes. The logged-in user is considered a member of the first class matched.
    n
    Number of users.
    times
    Day-of-week and time-of-day when the class can connect. Use Any for any day.
    message-file
    Message file that is displayed if a user is denied access.
Example 28–2 Setting User Login Limits
limit   anon     50  Wk0800-1800		/etc/ftpd/ftpmsg.deny
limit   anon    100  Any				/etc/ftpd/ftpmsg.deny
limit   guest   100  Any				/etc/ftpd/ftpmsg.deny
The first line of the preceding example shows a limit of 50 simultaneous logins that are allowed to users of class anon during weekly work hours. The second line limits anon users to 100 simultaneous logins outside of working hours. The last line shows a limit of 100 guest logins that are allowed at any time. For information on how to specify day and time parameters, see ftpaccess(4).
The example further indicates that the content of the file /etc/ftpd/ftpmsg.deny is returned when a specified login limit is reached, assuming ftpmsg.deny exists. For information on using the /usr/sbin/ftpcount command to view the number and login limit for each class of user who is logged in at a particular time, see ftpcount(1).
Users are allowed login to the FTP server unless a specified limit is reached. Anonymous users are logged in as the user ftp. Real users are logged in as themselves, and guests are logged in as real users with a chroot environment to limit access privileges.
For information on using the /usr/sbin/ftpwho command to check the identities of the users logged into the FTP server, see ftpwho(1).
ProcedureHow to Control the Number of Invalid Login Attempts
If a login to the FTP server fails because of a problem such as misspelling required information, login is usually repeated. The user is allowed a specific number of consecutive login attempts before a message is logged to the syslog file. At that point, the user is disconnected. You can set a failure limit on the number of login attempts by following steps in the next procedure.
  2. Add the following entries to the ftpaccess file.
    loginfails n
    loginfails
    Keyword that is used to assign the number of login failures that are permitted before the FTP connection is terminated
    n
    Number of times a login can fail
Example 28–3 Controlling the Number of Invalid Login Attempts
loginfails 10
The preceding example states that the user is disconnected from the FTP server after 10 failed login attempts.
ProcedureHow to Disallow FTP Server Access to Particular Users
The /etc/ftpd/ftpusers file lists names of users who are not allowed to log in to the FTP server. When login is attempted, the FTP server checks the /etc/ftpd/ftpusers file to determine whether the user should be denied access. If the user's name is not found in that file, the server then searches the /etc/ftpusers file.
If the user's name is matched in /etc/ftpusers, a syslogd message is written with a statement that the match was found in a deprecated file. The message also recommends the use of /etc/ftpd/ftpusers instead of /etc/ftpusers.
Note –
Support for the /etc/ftpusers file has been deprecated in this release. If the /etc/ftpusers file exists when the FTP server is installed, the file is moved to /etc/ftpd/ftpusers.
For additional information, see syslogd(1M), in.ftpd(1M), and ftpusers(4)
  2. Add entries to the /etc/ftpd/ftpusers file for users who are not allowed to log in to the FTP server.
Example 28–4 How to Disallow FTP Server Access
root
daemon
bin
sys
adm
lp
uccp
nuucp
listen
nobody
noaccess
nobody4
The previous example lists the typical entries in the ftpusers file. User names match entries in the /etc/passwd. The list generally includes the root and other administrative and system application identities.
The root entry is included in the ftpusers file as a security measure. The default security policy is to disallow remote logins for root. The policy is also followed for the default value that is set as the CONSOLE entry in the /etc/default/loginfile. See login(1).
ProcedureHow to Restrict Access to the Default FTP Server
In addition to the controls mentioned previously, you can add explicit statements to the ftpaccess file to restrict access to the FTP server.
    1. By default, all users are allowed access to the default (non-virtual) FTP server. To deny access for specific users (other than anonymous), add the following entry:
      defaultserver deny username [username...]
      defaultserver
      Keyword that is used to identify the non-virtual server to which access can be denied or allowed
      username
      Login name of a user with restricted access to the defaultserver
    2. To allow access for users who are not listed on the deny line, add the following line:
      defaultserver allow username [username...]
    3. To prevent access by anonymous users, add the entry:
      defaultserver private
Example 28–5 Restricting Access to the Default FTP Server
defaultserver deny *
The previous example states that the FTP server denies access to all users except anon users and those users who are listed on the allow line.
You can also use the ftphosts file to deny access to particular login accounts from various hosts. See ftphosts(4) for additional information.
Setting Up FTP Server Logins
To access an FTP server, you must first log in. The FTP server supports three types of user login accounts for real, guests, and anonymous users.
ProcedureHow to Set Up Real FTP Users
To enable access for real users to the FTP server, follow these instructions:
  1. Verify that the user has an account that is set up with a user name and password that can be used to establish a terminal session.
    For more information, see Chapter 4, Managing User Accounts and Groups (Overview), in System Administration Guide: Basic Administration.
  2. Confirm that the real user is a member of a class in the ftpaccess file.
    For information on the user classes that are defined in the ftpaccess file, see How to Define FTP Server Classes.
  3. Verify that the user's login shell is listed in the /etc/shells file.
ProcedureHow to Set Up Guest FTP Users
The ftpconfig script is used to copy all necessary system files to the home directory. When the guest user and the guest's home directory already exist, the ftpconfig script updates the area with the current system files.
For more information, see ftpconfig(1M)
Note –
Unlike the user name (anonymous or ftp) that is set for anonymous users, user names for FTP guests are not fixed. Any name that would work as a real user name can be selected.
To enable access by a guest user to the FTP server, do the following:
  1. Use the useradd script to create a guest user account with a login shell of /bin/true and a home directory of /root-dir/./home-dir.
    For more information, see useradd(1M) and Chapter 4, Managing User Accounts and Groups (Overview), in System Administration Guide: Basic Administration.
    Note –
    In this procedure, /home/guests/./guest1 is used as the home directory name for a user who is called guest1.
    # /usr/sbin/useradd -m -c "Guest FTP" -d \
      /home/guests/./guest1 -s /bin/true guest1
  2. Assign a password to the guest account.
  3. Add a guestuser entry to the ftpaccess file.
    guestuser guest1
    Note –
    You can also use the guestgroup capability in the ftpaccess file to specify guest users. The guest-root capability in ftpaccess eliminates the need for the /./ in the guest user's home directory path.
  4. Confirm that the guest user is a member of a class in the ftpaccess file. See How to Define FTP Server Classes for further information.
  5. Use the ftpconfig script to create the required files in the chroot area.
    /usr/sbin/ftpconfig -d /home/guests
  6. Confirm that /bin/true is listed in the /etc/shells file. See How to Create the /etc/shells file.
Example 28–6 Setting Up a Guest FTP Server
In this example, the FTP area is set up in the /home/guests directory.
# /usr/sbin/ftpconfig -d /home/guests
Updating directory /home/guests
ProcedureHow to Set Up Anonymous FTP Users
The ftpconfig script creates the anonymous user account and populates the home directory with the required files.
For more information, see ftpconfig(1M).
To enable access by an anonymous user to the FTP server, follow these instructions:
  1. Use the ftpconfig script to create the anonymous user account.
    /usr/sbin/ftpconfig anonymous-ftp-directory
  2. Confirm that the anonymous user is assigned to a class in the ftpaccess file.
Example 28–7 Setting Up Anonymous FTP Users
In this example, the FTP area is set up in the /home/ftp directory.
# /usr/sbin/ftpconfig /home/ftp
Creating user ftp
Updating directory /home/ftp
ProcedureHow to Create the /etc/shells file
  2. Create the /etc/shells file.
  3. Edit /etc/shells. Add the full path to each shell on a single line.
Example 28–8 Creating the /etc/shells file
The following is an example of an /etc/shells file with a /bin/true listed for FTP guest users:
/sbin/sh
/bin/csh
/bin/jsh
/bin/ksh
/bin/remsh
/bin/rksh
/bin/rsh
/bin/sh
/usr/bin/csh
/usr/bin/ksh
/usr/bin/bash
/usr/bin/tcsh
/usr/bin/zsh
/bin/true
Customizing Message Files
You can configure the FTP server to return messages that are related to specific events to the FTP client. A welcome message might be set to display when a user logs in to the FTP server. Another message could appear when the user makes a directory change.
In addition to plain text, message files can contain one or more magic cookies. A magic cookie is composed of a % (percent sign), followed by a single character. When you embed a cookie in message text, information that is associated with the cookie appears on screen at the point the message file is called.
For example, message text might contain the cookie %L:
Welcome to %L!
When the message is displayed, the magic cookie %L is replaced with the name of the server as defined by the hostname statement in the ftpaccess file. For a complete list of supported message cookies, see ftpaccess(4).
Note –
If the host name is not defined in the ftpaccess file, the default host name for the local machine is used.
ProcedureHow to Customize Message Files
  2. Edit your message file to include magic cookies as appropriate.
    See ftpaccess(4) for a list of cookies you can use.
Example 28–9 Customizing Message Files
The following is an example of a message file that includes magic cookies:
Welcome to %L -- local time is %T.
You are number %N out of a maximum of %M.
All transfers are logged.
If your FTP client crashes or hangs shortly after login
please try
using a dash (-) as the first character of your password.
This will
turn off the informational messages that may be confusing
your FTP
client.
Please send any comments to %E.
ProcedureHow to Create Messages to Be Sent to Users
After the user is logged in, system-related or application-related messages are displayed on screen. The ftpaccess file lists the events that trigger associated message statements.
    message message-file [when [class ...]]
    message
    Keyword that is used to specify the message file to be displayed when a user logs in or executes the command to change the working directory.
    message-file
    Name of the message file to be displayed.
    when
    Parameter that is set as login or cwd=dir. See the following example.
    class
    The class specification allows the message to be displayed only to members of a particular class.
Example 28–10 Creating Messages to Be Sent to Users
message	/etc/ftpd/Welcome	login   anon guest
message	.message	cwd=*
The preceding example states that the file /etc/ftpd/Welcome is displayed at login for users of the class anon or guest. The second line states that the .message file in the current working directory is displayed for all users.
Message files are created relative to the chroot directory for guest and anonymous users.
ProcedureHow to Configure the README Option
The first time a directory is visited, README files can be listed. To configure the README option, add the following entries to the ftpaccess file.
    readme message-file [when [class...]]
    readme
    Keyword that is used to specify a message file to be checked when a user logs in or changes the working directory. If the message file exists, the user is notified and is given the date the file was modified.
    message-file
    Name of the message file to be checked.
    when
    class
    Note –
    The greeting and banner keywords can also be used to send messages to users. See ftpaccess(4).
Example 28–11 Configuring the README Option
readme  README*     login
readme  README*     cwd=*
The previous example states that any files that match README* are listed at login or when a directory is changed. Here is a sample login that is based on the settings that are used in that example.
% ftp earth
Connected to earth.
220 earth FTP server ready.
Name (earth:rimmer): ftp
331 Guest login ok, send your complete e-mail address as password.
Password:
230-
230-Welcome to earth -- local time is Thu Jul 15 16:13:24
1999.
230-
230-You are number 1 out of a maximum of 10.
230-All transfers are logged.
230-
230-If your FTP client crashes or hangs shortly after login
please try
230-using a dash (-) as the first character of your
password.  This will
230-turn off the informational messages that may be
confusing your FTP
230-client.
230-
230-Please send any comments to ftpadmin@earth.
230-
230 Guest login ok, access restrictions apply.
ftp> cd pub
250-Please read the file README
250-  it was last modified on Thu Jul 15 16:12:25 1999 - 0
days ago
250 CWD command successful.
ftp> get README /tmp/README
200 PORT command successful.
150 Opening ASCII mode data connection for README (0
bytes).
226 ASCII Transfer complete.
ftp> quit
221 Goodbye.
Controlling Access to Files on the FTP Server
The FTP server access controls in this section supplement the standard file and directory access controls available with the Solaris release. Use the standard Solaris commands to restrict who can access, change, or upload files. See chmod(1), chown(1), and chgrp(1).
ProcedureHow to Control File Access Commands
To use the permission capabilities in ftpaccess to specify what type of user is allowed to perform which commands, do the following:
  2. Add the following entries to the ftpaccess:
    command yes|no typelist
    command
    The commands chmod, delete, overwrite, rename, or umask
    yes|no
    Allows or disallows a user to issue a command
    typelist
    A comma-separated list of any of the keywords anonymous, guest, and real
Example 28–12 How to Control File Access Commands
The following are examples of permissions that are set for file access functions on FTP server.
chmod no anonymous, guest
delete    no anonymous
overwrite no anonymous
rename    no anonymous
umask     no guest, anonymous
The preceding example states the following:
You can control uploads and downloads that are started to and from the FTP server by setting permissions on directories on the server. By default, uploads are not allowed for anonymous users. Be very careful when enabling anonymous uploads.
ProcedureHow to Control Uploads to the FTP Server
Add the directives to the ftpaccess file to specify upload permissions and error messages for upload failures.
    To enable users to upload files, add the following entry:
    upload [absolute|relative] [class=<classname>]... [-] root-dir \
    dirglob yes|no owner group mode [dirs|nodirs] [<d_mode>]
    path-filter typelist mesg allowed-charset {disallowed regexp...}
    upload
    Keyword that is applied to users who have a home directory (the argument to chroot()) of the root-dir. The root-dir can be specified as “*” to match any home directory.
    absolute|relative
    Parameter that specifies whether the root-dir directory paths are interpreted as absolute or relative to the current chroot directory.
    class
    Keyword that is used to specify any number of class=<classname> restrictions. If restrictions are specified, the upload clause only becomes effective if the current user is a member of one of the specified classes.
    root-dir
    User's root directory and the home directory for anonymous users.
    dirglob
    A pattern to match a directory name. An asterisk can be used in any place or alone to signify any directory.
    yes|no
    Variable that allows or disallows upload to the FTP server.
    owner
    Owner of files that are uploaded into dirnames.
    group
    Group that is associated with files that are uploaded into dirnames.
    mode
    Parameter that is used to specify access permissions for uploaded files. The default mode 0440 prevents the anonymous account from reading uploaded files.
    dirs|nodirs
    Keyword that allows or disallows users to create subdirectories in a directory that is listed in dirnames.
    d_mode
    Optional mode that determines the permissions for a newly created directory.
    path-filter
    Keyword that controls the names of uploaded files.
    typelist
    A comma-separated list of any of the keywords anonymous, guest, and real.
    mesg
    Message file that is displayed fails to match the regexp criteria.
    Alphanumeric characters allowed or disallowed in file names.
Example 28–13 Controlling Uploads to the FTP Server
upload /export/home/ftp /incoming yes ftpadm ftpadmin 0440 nodirs
path-filter anonymous /etc/ftpd/filename.msg ^[-A-Za-z0-9._]*$ ^[.-]
Ownership and permissions on a directory into which anonymous uploads are allowed should be tightly controlled. The FTP Administrator should be the owner of all files uploaded to the FTP server. You need to create an FTP Administrator when anonymous users are allowed to upload files. The directory should be owned by the user ftpadm and group ftpadm with permissions set to 3773.
The access mode for files uploaded to the FTP server should be 0440. The 0440 mode prevents the anonymous account from reading uploaded files. This restriction protects your server from becoming a staging area for third-party file distribution.
To make uploaded files available for distribution, the FTP Administrator can move files to a public directory.
ProcedureHow to Control Downloads to the FTP Server
  2. Add the following entries to the ftpaccess file to prevent users from retrieving files.
    noretrieve [absolute|relative] [class=classname]... [-] filename ...
    noretrieve
    Keyword that is used to deny retrieval of a particular file or files
    absolute|relative
    class
    Keyword that is used to specify class=<classname> of users to which noretrieve restrictions apply
    filename
    Name of file the user is not permitted to retrieve
Example 28–14 Controlling Downloads to the FTP Server
noretrieve /etc/passwd
The preceding example states that all users are prevented from retrieving the /etc/passwd file.
Virtual Hosting
Virtual hosting allows the FTP server to support multiple domains on the same machine. Each virtual host requires a separate logical interface and IP address.
The FTP server supports two types of virtual hosting: limited and complete. With limited virtual hosting, the same configuration files are used for all virtual hosts. With complete virtual hosting, separate configuration files can be used for each virtual host.
Note –
By default, real and guest users are not allowed to log in to virtual hosts. You can set the following ftpaccess directives to override the default.
To allow access to specific users:
virtual address allow username
To deny access to anonymous users:
virtual address private username
See ftpaccess(4) for further information.
ProcedureHow to Enable Limited Virtual Hosting
Limited virtual hosting provides partial support for virtual FTP servers. You can enable support for limited virtual hosting by specifying the virtual root directory. If required, you can also set the following parameters for the virtual host in the ftpaccess file:
All directives in the ftpaccess file are shared globally across all virtual servers.
    virtual address root|banner|logfile path
    virtual address hostname|email string
    virtual
    Keyword that is used to enable virtual server capabilities
    address
    IP address of the virtual server
    root
    The root directory of the virtual server
    banner
    Banner file that is displayed when a connection is made to the virtual server
    logfile
    Record of file transfers that are made to and from the virtual server
    path
    Variable that is used to specify the location of directories and files on the virtual server
    email
    Email address that is used in message files and in the HELP command
    hostname
    Name of the host that is shown in the greeting message or status command
    string
    Variable that is used to specify email or hostname parameters
    Note –
    While it is possible to use hostname as the address of the virtual server, you are strongly encouraged to use the IPv4 address instead. DNS must be available when the FTP connection is received in order for hostname to be matched. For an IPv6 host, use the host name rather than the IPv6 address.
Example 28–15 Enabling Limited Virtual Hosting in the ftpaccess File
virtual 10.1.2.3 root    /var/ftp/virtual/ftp-serv
virtual 10.1.2.3 banner  /var/ftp/virtual/ftp-serv/banner.msg
virtual 10.1.2.3 logfile /var/log/ftp/virtual/ftp-serv/xferlog
The preceding example sets the location of the root directory, banner, and logfile on a virtual FTP server.
Example 28–16 Enabling Limited Virtual Hosting on the Command Line
The ftpaddhost(1M) script with the -l option is provided to configure limited virtual hosts.
In the following example, ftpaddhost is run with -l -b -x options to configure limited virtual hosting with a test banner and the logfile /var/ftp/virtual/10.1.2.3/xferlog under a virtual root /var/ftp/virtual/10.1.2.3.
# ftpaddhost -l -b -x /var/ftp/virtual/10.1.2.3/xferlog \
ProcedureHow to Enable Complete Virtual Hosting
Complete virtual hosting allows separate configuration files for each virtual domain. To enable complete support for virtual hosting on the FTP server, you can create or modify the following FTP configuration files for specific domains:
For further information, see ftpaccess(4), ftpusers(4), ftpgroups(4), ftphosts(4), and ftpconversions(4).
Note –
If separate versions of the configuration files are unavailable, master versions of the files in the /etc/ftpd directory are used.
  2. Add the following entry to the /etc/ftpd/ftpservers file.
    address /config-file-dir
    address
    config-file-dir
    Directory that contains the configuration files that are customized for the virtual host
    Note –
  3. To create a customized version of an FTP server configuration file for the virtual host, copy the master version of the file from /etc/ftpd to the /config-file-dir directory.
    For further information, see ftpservers(4).
Example 28–17 Enabling Complete Virtual Hosting in the ftpservers file
# FTP Server virtual hosting configuration file
10.1.2.3 /net/inet/virtual/somedomain/
10.1.2.4 /net/inet/virtual/anotherdomain/
The preceding example specifies the IP addresses for two different domains on the virtual server.
Example 28–18 Enabling Complete Virtual Hosting from the Command Line
The ftpaddhost(1M) script with the -c option is provided to configure complete virtual hosts.
In the following example, ftpaddhost is run with -c -b -x options to configure complete virtual hosting with a test banner and the logfile /var/ftp/virtual/10.1.2.3/xferlog under a virtual root /var/ftp/virtual/10.1.2.3.
# ftpaddhost -c -b -x /var/ftp/virtual/10.1.2.3/xferlog \
Starting the FTP Server Automatically
The FTP server can be started in one of three ways:
A standalone server always has the quickest possible response time, and is intended for large servers that are dedicated to providing FTP service. The standalone server provides low connection latency for dedicated servers because the standalone system never has to be restarted. The standalone server is always running, even during off-peak hours, waiting indefinitely for connections.
ProcedureHow to Start an FTP Server Using SMF
By default, the SMF service is configured to start the FTP server using the nowait mode. If the site handles many connections, the FTP server can also be run in standalone mode. See the in.ftpd(1M) man page for information on additional command-line options.
  2. Verify the wait property for the FTP server.
    The line reporting that wait=FALSE indicates that the server is started in nowait mode.
    # inetadm -l network/ftp
    SCOPE    NAME=VALUE
             name="ftp"
             endpoint_type="stream"
             proto="tcp6"
             isrpc=FALSE
             wait=FALSE
             exec="/usr/sbin/in.ftpd -a"
             user="root"
    default  bind_addr=""
    default  bind_fail_max=-1
    default  bind_fail_interval=-1
    default  max_con_rate=-1
    default  max_copies=-1
    default  con_rate_offline=-1
    default  failrate_cnt=40
    default  failrate_interval=60
    default  inherit_env=TRUE
    default  tcp_trace=FALSE
    default  tcp_wrappers=FALSE
  3. Start the FTP server.
    # svcadm enable network/ftp
ProcedureHow to Start a Standalone FTP Server in the Background
  2. Disable the FTP server.
    # svcadm disable network/ftp
  3. Start the standalone FTP server.
    # /usr/sbin/in.ftpd -a -S
    Add the line to an FTP server startup script. See Using Run Control Scripts in System Administration Guide: Basic Administration for information on creating a system startup script.
ProcedureHow to Start a Standalone FTP Server in the Foreground
  3. Add an entry to the inittab file to start the service.
    The new entry in /etc/inittab should look something like the following:
    ftpd:3:respawn:/usr/sbin/in.ftpd -a -s
  4. Tell init to re-examine /etc/inittab.
    This command should start the FTP service.
    # init q
The ftpshut(1M) command closes down the FTP server at a particular time.
When you run ftpshut, a file is generated from command-line options that specify when shutdown occurs, the point at which new connections are refused, and when existing connections are dropped. Users are notified of a server shutdown based on this information. The location of the file that is created by ftpshut is specified by the shutdown directive in the ftpaccess file.
ProcedureHow to Shut Down the FTP Server
Follow the steps in this procedure to run ftpshut and to add the shutdown directive to the ftpaccess file.
    shutdown path
    shutdown
    Keyword that is used to specify the path to a file that is checked regularly for whether the FTP server is scheduled to be shut down
    path
    Location of the file that was created by ftpshut command
  3. Run the ftpshut command.
    ftpshut [ -V ] [ -l min] [ -d min] time [warning-message...]
    ftpshut
    Command that provides a procedure for notifying users that the FTP server is shutting down.
    -V
    Option that is specified to display copyright and version information, then terminate
    -l
    Flag that is used to adjust the time that new connections to the FTP server are denied
    -d
    Flag that is used to adjust the time that existing connections to the FTP server are disconnected.
    time
    Shutdown time that is specified by the word now for immediate shutdown, or in one of two formats (+ number or HHMM) for a future shutdown
    Shutdown notification message
  4. Use the ftprestart command to restart the FTP server after shutdown.
    For further information, see ftpshut(1M), ftpaccess(4), and ftprestart(1M).
Debugging the FTP Server
This section describes some of the ways to debug problems with the FTP server.
ProcedureHow to Check syslogd for FTP Server Messages
The FTP server writes messages that are useful for debugging to the location that is specified for daemon messages in the /etc/syslog.conf file. If a problem occurs with the FTP server, check this file first for such messages.
The FTP server messages are controlled by facility daemon and level information. To send messages from the FTP server to /var/adm/message and have syslogd reread its configuration file, follow these instructions:
  1. Add an entry such as the following to the /etc/syslog.conf file.
    daemon.info /var/adm/message
  2. Signal syslogd to reread its configuration.
    # svcadm refresh system/system-log
    This action causes informational messages from the FTP Sever to be written to /var/adm/messages.
ProcedureHow to Use greeting text to Verify ftpaccess
To use the greeting text capability to check that the correct ftpaccess file is being used, do the following:
  1. Add the following directive to the ftpaccess file.
    greeting text message
  2. Connect to the FTP server.
  3. If the message fails to appear, do the following:
    1. Confirm that the ftpaccess file is in the correct location. Use the strings(1) command to obtain the location of the file from the FTP server binary.
      # strings /usr/sbin/in.ftpd | grep "^/.*ftpaccess"
    2. Check the ftpservers file to see if virtual hosting has been configured.
      For further information, see ftpaccess(4), ftpservers(4), strings(1), syslog.conf(4), and pgrep(1).
ProcedureHow to Check the Commands Executed by FTP Users
To see what commands are being executed by FTP users, use the log commands logging capability in ftpaccess.
  1. Add the following directive to the ftpaccess file to log individual commands by users who are specified in typelist.
    log commands typelist
  2. Check messages that are written to the location specified in the /etc/syslog.conf.
Configuration Help for Busy Sites
The following list includes some suggestions to improve performance on busy FTP sites.
  1. Sites which typically support many simultaneous connections should run the FTP server in standalone mode, see Starting the FTP Server Automatically.
  2. Use vmstat and other system utilities to monitor the system hosting the FTP server. If the system runs low on resources place a limit on the number of simultaneous connections, see How to Set User Login Limits. For more information on system monitoring, see Chapter 13, Monitoring System Performance (Tasks), in System Administration Guide: Advanced Administration.
  3. If you impose a connection limit, consider using the limit-time and timeout idle capabilities in the ftpaccess file to stop users from hogging connections. If you don't impose a connection limit, specify the -Q option to in.ftpd.
  4. If you don't need ftp login and logout records in /var/adm/wtmpx, specify the -W option to in.ftpd.
  5. To reduce the load on the system hosting the FTP server, increase the transfer buffer sizes using the recvbuf and sendbuf capabilities in the ftpaccess file. If large buffer sizes are selected it may be necessary to increase the data activity timeout using the timeout data capability in the ftpaccess file.
  6. The FTP server reads from various databases including the hosts, passwd, group and services. Slow lookups may cause a significant delay logging into the FTP server, configuring the files source first in nsswitch.conf minimizes the lookup times. For more information, see the nsswitch.conf(4) man page.
  7. By default the FTP server attempts to lookup the remote host's name, which can be slow causing a significant delay logging in. The rhostlookup capability in the ftpaccess file can be used to stop this lookup. However be aware that if the remote host's name is not looked up, only its IP address is matched when using other capabilities in the ftpaccess file and when matching entries in the ftphosts file. Also the remote host's IP address will be used in messages and in place of the %R magic cookie. See the description of the rhostlookup capability in the ftpaccess(4) man page for more details.
  8. Retrieving quota information may also cause a significant delay when logging into the FTP server, so only use the quota-info capability in the ftpaccess file if you make use of the quota magic cookies. See the ftpaccess(4) man page for a list of the quota magic cookies.
