System Administration Guide: Network Services
ProcedureHow to Control Downloads to the FTP Server
  1. Become superuser or assume an equivalent role.
    Roles contain authorizations and privileged commands. For more information about roles, see Configuring RBAC (Task Map) in System Administration Guide: Security Services.
  2. Add the following entries to the ftpaccess file to prevent users from retrieving files.
    noretrieve [absolute|relative] [class=classname]... [-] filename ...
    Keyword that is used to deny retrieval of a particular file or files
    Parameter that specifies whether the root-dir directory paths are interpreted as absolute or relative to the current chroot directory
    Keyword that is used to specify class=<classname> of users to which noretrieve restrictions apply
    Name of file the user is not permitted to retrieve
Example 28–14 Controlling Downloads to the FTP Server
noretrieve /etc/passwd
The preceding example states that all users are prevented from retrieving the /etc/passwd file.
