System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
NIS-Related Commands
The NIS service includes specialized daemons, system programs, and commands, which are summarized in the following table.
Table 4–4 NIS Command Summary
Command
Description
ypserv
Services NIS clients' requests for information from an NIS map. ypserv is a daemon that runs on NIS servers with a complete set of maps. At least one ypserv daemon must be present on the network for NIS service to function.
ypbind
Provides NIS server binding information to clients. It provides binding by finding a ypserv process that serves maps within the domain of the requesting client. ypbind must run on all servers and clients.
ypinit
Automatically creates maps for an NIS server from the input files. It is also used to construct the initial /var/yp/binding/domain/ypservers file on the clients. Use ypinit to set up the master NIS server and the slave NIS servers for the first time.
make
Updates NIS maps by reading the Makefile (when run in the /var/yp directory). You can use make to update all maps based on the input files or to update individual maps. The ypmake(1M) man page describes the functionality of make for NIS.
makedbm
makedbm takes an input file and converts it into dbm.dir and dbm.pag files – valid dbm files that NIS can use as maps. You can also use makedbm -u to disassemble a map, so that you can see the key-value pairs that comprise it.
ypxfr
Pulls an NIS map from a remote server to the local /var/yp/domain directory, using NIS itself as the transport medium. You can run ypxfr interactively, or periodically from a crontab file. It is also called by ypserv to initiate a transfer.
ypxfrd
Provides map transfers service for ypxfr requests (generally slave servers). It is run only on the master server.
yppush
Copies a new version of an NIS map from the NIS master server to its slaves. You run it on the master NIS server.
ypset
Tells a ypbind process to bind to a named NIS server. This is not for casual use and its use is discouraged because of security implications. See the ypset(1M) and ypbind(1M) man pages for information about the ypset and ypsetme options to the ypbind process.
yppoll
Tells which version of an NIS map is running on a server that you specify. It also lists the master server for the map.
ypcat
Displays the contents of an NIS map.
ypmatch
Prints the value for one or more specified keys in an NIS map. You cannot specify which version of the NIS server map you are seeing.
ypwhich
Shows which NIS server a client is using at the moment for NIS services, or, if invoked with the -m mapname option, which NIS server is master of each of the maps. If only -m is used, it displays the names of all the maps available and their respective master servers.
