System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Adding Entries to a File-Based Map
Adding entries to mymap is simple. First, you must modify the text file /var/yp/mymap.asc. If you modify the actual dbm files without modifying the corresponding text file, the modifications are lost. Then run makedbm as shown above.
