System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Using Per-User Credentials
Note –
Do not edit either of the client configuration files directly. Use the ldapclient command to create or modify the content of these files.
ProcedureHow to Initialize a Client Using Per-User Credentials
Before You Begin
Before you set up a client with per-user credentials the following items must already be configured:
  1. Run ldapclient init to initialize the client by using the gssapi profile:
    # /usr/sbin/ldapclient init -a profilename=gssapi_SPARKS.COM -a \
  2. Try to log in as a user:
    Run kinit -p user.
    Run ldaplist -l passwd user in user's login session and you should see “userpassword.”
    But ldaplist -l passwd bar can get the entry without userpassword. By default root can still see userpassword of everybody.
Notes About Using Per-User Credentials
See other references in this guide and in the System Administration Guide: Security Services for details.
