Starting in the Solaris 10 10/09 release, the enableShadowUpdate switch is available.
Become superuser or assume an equivalent role.
Roles contain authorizations and privileged commands. For more information about roles, see Chapter 9, Using Role-Based Access Control (Tasks), in System Administration Guide: Security Services.
To set the enableShadowUpdate switch and define the admin credential, run the ldapclient command.
To update an already running client, run this command:
# ldapclient mod -a enableShadowUpdate=TRUE \ -a adminDN=cn=admin,ou=profile,dc=west,dc=example,dc=com \ -a adminPassword=admin-password System successfully configured |
To initialize a client, run this command:
# ldapclient init \ -a adminDN=cn=admin,ou=profile,dc=west,dc=example,dc=com \ -a adminPassword=admin-password -a domainName=west.example.com \ -a profileName=WestUserProfile \ -a proxyDN=cn=proxyagent,ou=profile,dc=west,dc=example,dc=com \ -a proxyPassword=i<proxy_password> \ 192.168.0.1 System successfully configured |
To verify the configuration, display the contents of the /var/ldap/ldap_client_cred file.
The output should contain lines similar to the following:
# cat /var/ldap/ldap_client_cred NS_LDAP_BINDDN= cn=proxyagent,ou=profile,dc=west,dc=example,dc=com NS_LDAP_BINDPASSWD= {NS1}4a3788f8eb85de11 NS_LDAP_ENABLE_SHADOW_UPDATE= TRUE NS_LDAP_ADMIN_BINDDN= cn=admin,ou=profile,dc=west,dc=example,dc=com NS_LDAP_ADMIN_BINDPASSWD= {NS1}4a3788f8c053434f |
