System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Statements in BIND 9
This section describes any differences between BIND 8 and BIND 9 statements.
The Controls Statement
unix is the default for ndc and all of the arguments are compiled in. inet is the only option for rndc and nothing is compiled in.
  Syntax
     controls {
       [ inet ip_addr
         port ip_port
         allow { address_match_list; }; ]	OK
       [ unix path_name
         perm number
         owner number
         group number; ]			Not Implemented
Logging syntax has changed significantly. See The named.conf Options for a list of named.conf options.
The Zone Statement
The syntax for the zone statement in the BIND 8 named.conf man page is.mostly supported for BIND 9 except for the following:
  [ pubkey number number number string; ]	Obsolete
  [ check-names ( warn | fail | ignore ); ]	Not Implemented
The ACL Statement
Works unchanged in BIND 9.
  Syntax
     acl name {
       address_match_list
The Key Statement
  Syntax
     key key_id {
       algorithm algorithm_id;
       secret secret_string;
The Trusted-Keys Statement
Works unchanged, however the code to use this statement has been turned off in BIND 9.2.4.
  Syntax
     trusted-keys {
       [ domain_name flags protocol algorithm key; ]
The Server Statement
support-ixfr is obsolete, however all of the following options work unchanged in BIND 9. Note the default for transfer-format has changed.
  Syntax
     server ip_addr {
       [ bogus yes_or_no; ]
       [ transfers number; ]
       [ transfer-format ( one-answer | many-answers ); ]
       [ keys { key_id [ key_id ... ] }; ]
       [ edns yes_or_no; ]
The Include Statement
  Syntax
     include path_name;
