System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Implementing rndc
The BIND 8 ndc and BIND 9 rndc name server control tools are not backward compatible. rndc can not talk to the BIND 8 name server and ndc can not talk to the BIND 9 name server. Features, options, default modes of operation, and configuration file requirements have changed. Therefore, using ndc on a BIND 9 server could result in loss of functionality or insecure operation. See the rndc(1M) man page for more information.
The rndc.conf Configuration File
The most significant difference between ndc in BIND 8 and rndc in BIND 9 is that rndc needs its own configuration file, rndc.conf. This file can be generated by rndc-confgen commands. The rndc.conf file specifies which server controls and what algorithm the server should use.
Example 3–1 Sample rndc.conf File
options {
             default-server localhost;
             default-key "rndc-key";
     key "rndc-key" {
             algorithm hmac-md5;
             secret "qPWZ3Ndl81aBRY9AmJhVtU==";
Example 3–2 Sample named.conf File Entry for rndc
controls {
             inet * allow { any; } keys { "rndc-key"; };
     key "rndc-key" {
             algorithm hmac-md5;
Differences in the Control Channels
Both the ndc and the rndc utilities use a control channel to send commands to and retrieve information from a name server. However, there are differences between the utilities.
Commands of BIND 9 rndc
The following list describes the rndc commands.
Reload configuration file and zones
reload zone [class [view]]
Reload a single zone
refresh zone [class [view]]
Schedule immediate maintenance for a zone
Reload configuration file and new zones only
Write server statistics to the statistics file
Toggle query logging
Dump cache(s) to the dump file (named_dump.db)
Save pending updates to master files and stop the server
Stop the server without saving pending updates
Increment debugging level by one
trace level
Change the debugging level
Set debugging level to 0
Flushes all of the server's caches
flush [view]
Flushes the server's cache for a view
Display status of the server
Restart the server (not yet implemented)
