System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Attribute Map
The Solaris LDAP naming service allows one or more attribute names to be remapped for any of its services. (The Solaris LDAP client uses the well-known attributes documented in Chapter 14, LDAP General Reference (Reference).) If you map an attribute, you must be sure that the attribute has the same meaning and syntax as the original attribute. Note that mapping the userPassword attribute might cause problems.
There are a couple of reasons you might want to use schema mappings.
The format for this attribute is service:attribute-name=mapped-attribute-name.
If you want to map more than one attribute for a given service, you can define multiple attributeMap attributes.
In the following example, the employeeName and home attributes would be used whenever the uid and homeDirectory attributes would be used for the passwd service.
attributeMap: passwd:uid=employeeName
attributeMap: passwd:homeDirectory=home
There exists one special case where you can map the passwd service's gecos attribute to several attributes. The following is an example.
attributemap: gecos=cn sn title
This maps the gecos values to a space separated list of the cn, sn, and title attribute values.
