The following table lists the client attributes that can be set locally using ldapclient. See the ldapclient(1M) man page for more information.
Starting in the Solaris 10 10/09 release, the enableShadowUpdate switch is available. For more information, see enableShadowUpdate Switch.
Table 9–3 Local Client Attributes
Attribute |
Description |
adminDN |
Specifies the administrator entry's distinguished name for the admin credential. If the value of the enableShadowUpdate switch is true on the client system, and credentialLevel has a value other than self, then adminDN must be specified. |
adminPassword |
Specifies the administrator entry's password for the admin credential. If the value of the enableShadowUpdate switch is true on the client system, and credentialLevel has a value other than self, then adminPassword must be defined. |
domainName |
Specifies the client's domain name (which becomes the default domain for the client system). This attribute has no default value and must be specified. |
proxyDN |
The proxy's distinguished name. If the client system is configured with credentialLevel of proxy, the proxyDN must be specified. |
proxyPassword |
The proxy's password. If the client system is configured with credentialLevel of proxy, proxyPassword must be defined. |
certificatePath |
The directory on the local file system containing the certificate databases. If a client system is configured with authenticationMethod or serviceAuthenticationMethod using TLS, then this attribute is used. The default value is /var/ldap. |
If the BaseDN in an SSD contains a trailing comma, it is treated as a relative value of the defaultSearchBase. The values of the defaultSearchBase are appended to the BaseDN before a search is performed.
