System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Credential Storage
If you configure a client to use a proxy identity, the client saves its proxyDN and proxyPassword in /var/ldap/ldap_client_cred. For the sake of increased security, this file is restricted to root access only, and the value of proxyPassword is encrypted. While past LDAP implementations have stored proxy credentials in a client's profile, Solaris 9 LDAP naming services do not. Any proxy credentials set using ldapclient during initialization are stored locally. This results in improved security surrounding a proxy's DN and password information. See Chapter 12, Setting Up LDAP Clients (Tasks) for more information on setting up client profiles.
Similarly, if you configure a client to enable shadow data updates, and the client credential level is not self, the client saves its adminDN and adminPassword attributes locally in the /var/ldap/ldap_client_cred file. The value of adminPassword is also encrypted and is used only by the ldap_cachemgr daemon process.
If you configure a client to use per-user authentication, the Kerberos identity and Kerberos ticket information for each principal (each user or host) are used during authentication. In this environment the directory server maps the Kerberos principal to a DN and the Kerberos credentials are used to authenticate to that DN. The directory server can then use its access control instruction (ACI) mechanisms to allow or deny access to naming service data as necessary. In this situation, Kerberos ticket information is used to authenticate to the directory server and the system does not store authentication DNs or passwords on the system. Therefore, for this type of configuration, you do not need to specify the adminDN and adminPassword attributes when the client is initialized with the ldapclient command.
