System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Authentication and Services
The authentication method can be specified for a given service in the serviceAuthenticationMethod attribute. The following services currently support this.
Note –
If the service does not have a serviceAuthenticationMethod set, it will default to the value of the authenticationMethod attribute.
Note –
In per-user mode, pam_krb5 Service Module (pam Kerberos) is used as the authentication service. ServiceAuthenticationMethod is not needed in this mode of operation.
Note –
If the enableShadowUpdate switch is set to true, the ldap_cachemgr daemon binds to the LDAP server by using the authentication method that is defined in the serviceAuthenticationMethod parameter of passwd-cmd, if the method is defined. Otherwise, authenticationMethod is used. The daemon will not use the none authentication method.
The following example shows a section of a client profile in which the users will use sasl/digest-MD5 to authenticate to the directory server, but will use an SSL session to change their password.
