System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Example 2–Implementing a Custom Map
This example shows how to implement a custom map.
A hypothetical map, servdate.bynumber, contains information about the servicing dates for systems. This map is indexed by the machine's serial number which, in this example, is 123. Each entry consists of the machine owner's name, a colon, and a comma-separated list of service dates, such as John Smith:1/3/2001,4/5/2003.
The old map structure is to be mapped onto LDAP entries of the following form:
dn: number=123,ou=servdates,dc=... \
                 number: 123 \
                 userName: John Smith \
                 date: 1/3/2001 \
                 date: 4/5/2003 \
                 objectClass: servDates
By examining the NISLDAPmapping file, you can see that the mapping closest to the required pattern is group. The custom mappings can be modeled on the group mapping. Since there is only one map, no nisLDAPdatabaseIdMapping attribute is required. The attributes to be added to NISLDAPmapping are the following:
nisLDAPentryTtl servdate.bynumber:1800:5400:3600
nisLDAPnameFields servdate.bynumber: \
                        ("%s:%s", uname, dates)
nisLDAPobjectDN servdate.bynumber: \
                        ou=servdates, ?one? \
nisLDAPattributeFromField servdate.bynumber: \
                        dn=("number=%s,", rf_key), \
                        number=rf_key, \
                        userName=uname, \
                        (date)=(dates, ",")
nisLDAPfieldFromAttribute servdate.bynumber: \
                        rf_key=number, \
                        uname=userName, \
                        dates=("%s,", (date), ",")
