System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
NIS-to-LDAP Issues
The following problems could occur while running the N2L server. Possible causes and solutions are provided.
Debugging the NISLDAPmapping File
The mapping file, NISLDAPmapping, is complex. Many potential errors might cause the mapping to behave in unexpected ways. Use the following techniques to resolve such problems.
Console Message Displays When ypserv -ir (or -Ir) Runs
NIS Daemon Exits at Startup
Unexpected Results From NIS Operations
Processing Order of NIS Maps
Note –
Mapping in such a way that all of an object's MUST attributes cannot be created from at least one map is not supported.
N2L Server Timeout Issue
N2L Lock File Issue
N2L Deadlock Issue
