System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
For Clients That Use pam_unix
To enable Solaris LDAP clients to use pam_unix for account management, the server must be set up to enable the updating of shadow data. This functionality is available starting in the Solaris 10 10/09 release. Unlike pam_ldap account management, pam_unix does not require extra configuration steps. All configuration can be performed by running the idsconfig utility. For a basic idsconfig run, see Example 11–1.
The following shows the output of two idsconfig runs.
The first idsconfig run uses an existing client profile.
# /usr/lib/ldap/idsconfig
It is strongly recommended that you BACKUP the directory server
before running idsconfig.
Hit Ctrl-C at any time before the final confirmation to exit.
Do you wish to continue with server setup (y/n/h)? [n] y
Enter the JES Directory Server's  hostname to setup: myserver
Enter the port number for iDS (h=help): [389]
Enter the directory manager DN: [cn=Directory Manager]
Enter passwd for cn=Directory Manager :
Enter the domainname to be served (h=help): [west.example.com]
Enter LDAP Base DN (h=help): [dc=west,dc=example,dc=com]
  Checking LDAP Base DN ...
  Validating LDAP Base DN and Suffix ...
  sasl/GSSAPI is not supported by this LDAP server
Enter the profile name (h=help): [default] WestUserProfile
Profile 'WestUserProfile' already exists, it is possible to enable
shadow update now. idsconfig will exit after shadow update
is enabled. You can also continue to overwrite the profile
or create a new one and be given the chance to enable
shadow update later.
Just enable shadow update (y/n/h)? [n] y
Add the administrator identity (y/n/h)? [y]
Enter DN for the administrator: [cn=admin,ou=profile,dc=west,dc=example,dc=com]
Enter passwd for the administrator:
Re-enter passwd:
  ADDED: Administrator identity cn=admin,ou=profile,dc=west,dc=example,dc=com.
         Proxy ACI LDAP_Naming_Services_proxy_password_read does not
         exist for dc=west,dc=example,dc=com.
  ACI SET: Give cn=admin,ou=profile,dc=west,dc=example,dc=com read/write access
           to shadow data.
  ACI SET: Non-Admin access to shadow data denied.
  Shadow update has been enabled.
The second idsconfig run creates a new profile for later use. Only partial output is displayed.
Enter the profile name (h=help): [default] WestUserProfile-new
Default server list (h=help): [192.168.0.1]
Do you want to enable shadow update (y/n/h)? [n] y
              Summary of Configuration
  1  Domain to serve               : west.example.com
  2  Base DN to setup              : dc=west,dc=example,dc=com
         Suffix to create          : dc=west,dc=example,dc=com
  3  Profile name to create        : WestUserProfile-new
 19  Enable shadow update          : TRUE
Re-enter passwd:
WARNING: About to start committing changes. (y=continue, n=EXIT) y
  1. Changed timelimit to -1 in cn=config.
  2. Changed sizelimit to -1 in cn=config.
  11. ACI for dc=test1,dc=mpklab,dc=sfbay,dc=sun,dc=com modified to
      disable self modify.
  15. Give cn=admin,ou=profile,dc=west,dc=example,dc=com write permission for shadow.
