System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Configuring the Directory Server to Enable Account Management
Starting in the Solaris 10 10/09 release, account management can be implemented for clients that use pam_ldap and for clients that use pam_unix.
Caution – Caution –
Do not use both pam_ldap and pam_unix in the same LDAP naming domain. Either all clients use pam_ldap or all clients use pam_unix. This limitation might indicate that you need a dedicated LDAP server.
For Clients That Use pam_ldap
In order for pam_ldap to work properly, the password and account lockout policy must be properly configured on the server. You can use the Directory Server Console or ldapmodify to configure the account management policy for the LDAP directory. For procedures and more information, see the “User Account Management” chapter in the Administration Guide for the version of Sun Java System Directory Server that you are using.
Note –
Previously, if you enabled pam_ldap account management, all users needed to provide a login password for authentication any time they logged in to the system. Therefore, nonpassword-based logins using tools such as rsh, rlogin, or ssh would fail.
Now, however, pam_ldap(5), when used with Sun Java System Directory Servers DS5.2p4 and newer releases, enables users to log in with rsh, rlogin, rcp and ssh without giving a password.
pam_ldap(5) is now modified to perform account management and retrieve the account status of users without authenticating to Directory Server as the user logging in. The new control to this on Directory Server is 1.3.6.1.4.1.42.2.27.9.5.8, which is enabled by default.
To modify this control for other than default, add Access Control Instructions (ACI) on Directory Server:
dn: oid=1.3.6.1.4.1.42.2.27.9.5.8,cn=features,cn=config
objectClass: top
objectClass: directoryServerFeature
oid:1.3.6.1.4.1.42.2.27.9.5.8
cn:Password Policy Account Usable Request Control
aci: (targetattr != "aci")(version 3.0; acl "Account Usable";
     allow (read, search, compare, proxy)
     (groupdn = "ldap:///cn=Administrators,cn=config");)
creatorsName: cn=server,cn=plugins,cn=config
modifiersName: cn=server,cn=plugins,cn=config
Passwords for proxy users should never be allowed to expire. If proxy passwords expire, clients using the proxy credential level cannot retrieve naming service information from the server. To ensure that proxy users have passwords that do not expire, modify the proxy accounts with the following script.
# ldapmodify -h ldapserver -D administrator DN \
-w administrator password <<EOF
dn: proxy user DN
DNchangetype: modify
replace: passwordexpirationtime
passwordexpirationtime: 20380119031407Z
EOF
Note –
pam_ldap account management relies on Sun Java System Directory Server to maintain and provide password aging and account expiration information for users. The directory server does not interpret the corresponding data from shadow entries to validate user accounts. pam_unix, however, examines the shadow data to determine if accounts are locked or if passwords are aged. Since the shadow data is not kept up to date by the LDAP naming services or the directory server, pam_unix should not grant access based on the shadow data. The shadow data is retrieved using the proxy identity. Therefore, do not allow proxy users to have read access to the userPassword attribute. Denying proxy users read access to userPassword prevents pam_unix from making an invalid account validation.
For Clients That Use pam_unix
To enable Solaris LDAP clients to use pam_unix for account management, the server must be set up to enable the updating of shadow data. This functionality is available starting in the Solaris 10 10/09 release. Unlike pam_ldap account management, pam_unix does not require extra configuration steps. All configuration can be performed by running the idsconfig utility. For a basic idsconfig run, see Example 11–1.
The following shows the output of two idsconfig runs.
The first idsconfig run uses an existing client profile.
# /usr/lib/ldap/idsconfig
It is strongly recommended that you BACKUP the directory server
before running idsconfig.
Hit Ctrl-C at any time before the final confirmation to exit.
Do you wish to continue with server setup (y/n/h)? [n] y
Enter the JES Directory Server's  hostname to setup: myserver
Enter the port number for iDS (h=help): [389]
Enter the directory manager DN: [cn=Directory Manager]
Enter passwd for cn=Directory Manager :
Enter the domainname to be served (h=help): [west.example.com]
Enter LDAP Base DN (h=help): [dc=west,dc=example,dc=com]
  Checking LDAP Base DN ...
  Validating LDAP Base DN and Suffix ...
  sasl/GSSAPI is not supported by this LDAP server
Enter the profile name (h=help): [default] WestUserProfile
Profile 'WestUserProfile' already exists, it is possible to enable
shadow update now. idsconfig will exit after shadow update
is enabled. You can also continue to overwrite the profile
or create a new one and be given the chance to enable
shadow update later.
Just enable shadow update (y/n/h)? [n] y
Add the administrator identity (y/n/h)? [y]
Enter DN for the administrator: [cn=admin,ou=profile,dc=west,dc=example,dc=com]
Enter passwd for the administrator:
Re-enter passwd:
  ADDED: Administrator identity cn=admin,ou=profile,dc=west,dc=example,dc=com.
         Proxy ACI LDAP_Naming_Services_proxy_password_read does not
         exist for dc=west,dc=example,dc=com.
  ACI SET: Give cn=admin,ou=profile,dc=west,dc=example,dc=com read/write access
           to shadow data.
  ACI SET: Non-Admin access to shadow data denied.
  Shadow update has been enabled.
The second idsconfig run creates a new profile for later use. Only partial output is displayed.
Enter the profile name (h=help): [default] WestUserProfile-new
Default server list (h=help): [192.168.0.1]
Do you want to enable shadow update (y/n/h)? [n] y
              Summary of Configuration
  1  Domain to serve               : west.example.com
  2  Base DN to setup              : dc=west,dc=example,dc=com
         Suffix to create          : dc=west,dc=example,dc=com
  3  Profile name to create        : WestUserProfile-new
 19  Enable shadow update          : TRUE
Re-enter passwd:
WARNING: About to start committing changes. (y=continue, n=EXIT) y
  1. Changed timelimit to -1 in cn=config.
  2. Changed sizelimit to -1 in cn=config.
  11. ACI for dc=test1,dc=mpklab,dc=sfbay,dc=sun,dc=com modified to
      disable self modify.
  15. Give cn=admin,ou=profile,dc=west,dc=example,dc=com write permission for shadow.
