System Administration Guide: Naming and Directory Services (DNS, NIS, and LDAP)
Example idsconfig Setup
This section provides an example of a basic idsconfig setup that uses many of the defaults. The most complicated method of modifying client profiles is to create SSDs. Refer to Using Service Search Descriptors to Modify Client Access to Various Services for a detailed discussion.
The data in square brackets after a prompt indicates the default value for that prompt. To accept the default value, press Return.
Note –
Any parameters that are left blank in the summary screen are not set up.
After idsconfig has completed the setup of the directory, you need to run the specified commands on the server before the server setup is complete and the server is ready to serve clients.
Example 11–1 Running idsconfig for the Example, Inc. Network
In the following example, the idsconfig utility is run immediately after a server instance is created on the LDAP server.
# usr/lib/ldap/idsconfig
It is strongly recommended that you BACKUP the directory server
before running idsconfig.
Hit Ctrl-C at any time before the final confirmation to exit.
Do you wish to continue with server setup (y/n/h)? [n] y
Enter the JES Directory Server's  hostname to setup: myserver
Enter the port number for iDS (h=help): [389]
Enter the directory manager DN: [cn=Directory Manager]
Enter passwd for cn=Directory Manager :
Enter the domainname to be served (h=help): [west.example.com]
Enter LDAP Base DN (h=help): [dc=west,dc=example,dc=com]
  Checking LDAP Base DN ...
  Validating LDAP Base DN and Suffix ...
  No valid suffixes were found for Base DN dc=west,dc=example,dc=com
Enter suffix to be created (b=back/h=help): [dc=west,dc=example,dc=com]
Enter ldbm database name (b=back/h=help): [west]
  sasl/GSSAPI is not supported by this LDAP server
Enter the profile name (h=help): [default] WestUserProfile
Default server list (h=help): [192.168.0.1]
Preferred server list (h=help):
Choose desired search scope (one, sub, h=help):  [one]
The following are the supported credential levels:
  1  anonymous
  2  proxy
  3  proxy anonymous
  4  self
  5  self proxy
  6  self proxy anonymous
Choose Credential level [h=help]: [1] 2
The following are the supported Authentication Methods:
  1  none
  2  simple
  3  sasl/DIGEST-MD5
  4  tls:simple
  5  tls:sasl/DIGEST-MD5
  6  sasl/GSSAPI
Choose Authentication Method (h=help): [1] 2
Current authenticationMethod: simple
Do you want to add another Authentication Method? n
Do you want the clients to follow referrals (y/n/h)? [n]
Do you want to modify the server timelimit value (y/n/h)? [n] y
Enter the time limit for iDS (current=3600): [-1]
Do you want to modify the server sizelimit value (y/n/h)? [n] y
Enter the size limit for iDS (current=2000): [-1]
Do you want to store passwords in "crypt" format (y/n/h)? [n] y
Do you want to setup a Service Authentication Methods (y/n/h)? [n]
Client search time limit in seconds (h=help): [30]
Profile Time To Live in seconds (h=help): [43200]
Bind time limit in seconds (h=help): [10]
Do you want to enable shadow update (y/n/h)? [n]
Do you wish to setup Service Search Descriptors (y/n/h)? [n]
              Summary of Configuration
  1  Domain to serve               : west.example.com
  2  Base DN to setup              : dc=west,dc=example,dc=com
         Suffix to create          : dc=west,dc=example,dc=com
         Database to create        : west
  3  Profile name to create        : WestUserProfile
  4  Default Server List           : 192.168.0.1
  5  Preferred Server List         :
  6  Default Search Scope          : one
  7  Credential Level              : proxy
  8  Authentication Method         : simple
  9  Enable Follow Referrals       : FALSE
 10  iDS Time Limit                : -1
 11  iDS Size Limit                : -1
 12  Enable crypt password storage : TRUE
 13  Service Auth Method pam_ldap  :
 14  Service Auth Method keyserv   :
 15  Service Auth Method passwd-cmd:
 16  Search Time Limit             : 30
 17  Profile Time to Live          : 43200
 18  Bind Limit                    : 10
 19  Enable shadow update          : FALSE
 20  Service Search Descriptors Menu
Enter config value to change: (1-20 0=commit changes) [0]
Enter DN for proxy agent: [cn=proxyagent,ou=profile,dc=west,dc=example,dc=com]
Enter passwd for proxyagent:
Re-enter passwd:
WARNING: About to start committing changes. (y=continue, n=EXIT) y
  1. Changed timelimit to -1 in cn=config.
  2. Changed sizelimit to -1 in cn=config.
  3. Changed passwordstoragescheme to "crypt" in cn=config.
  4. Schema attributes have been updated.
  5. Schema objectclass definitions have been added.
  6. Database west successfully created.
  7. Suffix dc=west,dc=example,dc=com successfully created.
  8. NisDomainObject added to dc=west,dc=example,dc=com.
  9. Top level "ou" containers complete.
  10. automount maps: auto_home auto_direct auto_master auto_shared processed.
  11. ACI for dc=west,dc=example,dc=com modified to disable self modify.
  12. Add of VLV Access Control Information (ACI).
  13. Proxy Agent cn=proxyagent,ou=profile,dc=west,dc=example,dc=com added.
  14. Give cn=proxyagent,ou=profile,dc=west,dc=example,dc=com read permission
      for password.
  15. Generated client profile and loaded on server.
  16. Processing eq,pres indexes:
      uidNumber (eq,pres)   Finished indexing.
      ipNetworkNumber (eq,pres)   Finished indexing.
      gidnumber (eq,pres)   Finished indexing.
      oncrpcnumber (eq,pres)   Finished indexing.
      automountKey (eq,pres)   Finished indexing.
  17. Processing eq,pres,sub indexes:
      ipHostNumber (eq,pres,sub)   Finished indexing.
      membernisnetgroup (eq,pres,sub)   Finished indexing.
      nisnetgrouptriple (eq,pres,sub)   Finished indexing.
  18. Processing VLV indexes:
      west.example.com.getgrent vlv_index   Entry created
      west.example.com.gethostent vlv_index   Entry created
      west.example.com.getnetent vlv_index   Entry created
      west.example.com.getpwent vlv_index   Entry created
      west.example.com.getrpcent vlv_index   Entry created
      west.example.com.getspent vlv_index   Entry created
      west.example.com.getauhoent vlv_index   Entry created
      west.example.com.getsoluent vlv_index   Entry created
      west.example.com.getauduent vlv_index   Entry created
      west.example.com.getauthent vlv_index   Entry created
      west.example.com.getexecent vlv_index   Entry created
      west.example.com.getprofent vlv_index   Entry created
      west.example.com.getmailent vlv_index   Entry created
      west.example.com.getbootent vlv_index   Entry created
      west.example.com.getethent vlv_index   Entry created
      west.example.com.getngrpent vlv_index   Entry created
      west.example.com.getipnent vlv_index   Entry created
      west.example.com.getmaskent vlv_index   Entry created
      west.example.com.getprent vlv_index   Entry created
      west.example.com.getip4ent vlv_index   Entry created
      west.example.com.getip6ent vlv_index   Entry created
idsconfig: Setup of iDS server myserver is complete.
Note: idsconfig has created entries for VLV indexes.
      For DS5.x, use the directoryserver(1m) script on myserver
      to stop the server.  Then, using directoryserver, follow the
      directoryserver examples below to create the actual VLV indexes.
      For DS6.x, use dsadm command delivered with DS6.x on myserver
      to stop the server.  Then, using dsadm, follow the
      dsadm examples below to create the actual VLV indexes.
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getgrent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.gethostent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getnetent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getpwent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getrpcent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getspent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getauhoent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getsoluent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getauduent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getauthent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getexecent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getprofent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getmailent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getbootent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getethent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getngrpent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getipnent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getmaskent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getprent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getip4ent
  directoryserver -s <server-instance> vlvindex -n west -T west.example.com.getip6ent
  <install-path>/bin/dsadm reindex -l -t west.example.com.getgrent <directory-instance-path>
  <install-path>/bin/dsadm reindex -l -t west.example.com.gethostent <directory-instance-path>
  <install-path>/bin/dsadm reindex -l -t west.example.com.getip6ent <directory-instance-path>
