System Administration Guide: Security Services
ProcedureHow to Create a New Kerberos Principal
An example of the command-line equivalent follows this procedure.
  1. If necessary, start the SEAM Tool.
    See How to Start the SEAM Tool for more information.
    Note –
    If you are creating a new principal that might need a new policy, you should create the new policy before you create the new principal. Go to How to Create a New Kerberos Policy.
    $ /usr/sbin/gkadmin
  2. Click the Principals tab.
  3. Click New.
    The Principal Basics panel that contains some attributes for a principal is displayed.
  4. Specify a principal name and a password.
    Both the principal name and the password are mandatory.
  5. Specify the encryption types for the principal.
    Click on the box to the right of the encryption key types field to open a new window that displays all of the encryption key types available. Click OK after selecting the required encryption types.
    Dialog box titled SEAM Encryption Type List Helper lists
all of the encryption types installed.
  6. Specify the policy for the principal.
  7. Specify values for the principal's attributes, and continue to click Next to specify more attributes.
    Three windows contain attribute information. Choose Context-Sensitive Help from the Help menu to get information about the various attributes in each window. Or, for all the principal attribute descriptions, go to SEAM Tool Panel Descriptions.
  8. Click Save to save the principal, or click Done on the last panel.
  9. If needed, set up Kerberos administration privileges for the new principal in the /etc/krb5/kadm5.acl file.
    See How to Modify the Kerberos Administration Privileges for more details.
Example 25–4 Creating a New Kerberos Principal
The following example shows the Principal Basics panel when a new principal called pak is created. The policy is set to testuser.
Dialog box titled SEAM Administration Tool shows account
data for the pak principal.  Shows password, account expiration date, and
testuser policy.
Example 25–5 Creating a New Kerberos Principal (Command Line)
In the following example, the add_principal command of kadmin is used to create a new principal called pak. The principal's policy is set to testuser.
kadmin: add_principal -policy testuser pak
Enter password for principal "pak@EXAMPLE.COM": <Type the password>
Re-enter password for principal "pak@EXAMPLE.COM": <Type the password again>
Principal "pak@EXAMPLE.COM" created.
kadmin: quit
