System Administration Guide: Security Services
ProcedureHow to Set Up Defaults for Creating New Kerberos Principals
No command-line equivalent exists for this procedure.
  1. If necessary, start the SEAM Tool.
    See How to Start the SEAM Tool for more information.
    $ /usr/sbin/gkadmin
  2. Choose Properties from the Edit Menu.
    The Properties window is displayed.
    Dialog box titled Properties shows defaults for new principals
and list controls. Defaults for principals cover security and other options.
  3. Select the defaults that you want to use when you create new principals.
    Choose Context-Sensitive Help from the Help menu for information about the various attributes in each window.
  4. Click Save.
