System Administration Guide: Security Services
Administering Keytab Files (Task Map)
Task
Description
For Instructions
Add a service principal to a keytab file.
Use the ktadd command of kadmin to add a service principal to a keytab file.
How to Add a Kerberos Service Principal to a Keytab File
Remove a service principal from a keytab file.
Use the ktremove command of kadmin to remove a service from a keytab file.
How to Remove a Service Principal From a Keytab File
Display the keylist (list of principals) in a keytab file.
Use the ktutil command to display the keylist in a keytab file.
How to Display the Keylist (Principals) in a Keytab File
Temporarily disable authentication for a service on a host.
This procedure is a quick way to temporarily disable authentication for a service on a host without requiring kadmin privileges.
Before you use ktutil to delete the service principal from the server's keytab file, copy the original keytab file to a temporary location. When you want to enable the service again, copy the original keytab file back to its proper location.
How to Temporarily Disable Authentication for a Service on a Host
