System Administration Guide: Security Services
ProcedureHow to Duplicate a Kerberos Policy
This procedure explains how to use all or some of the attributes of an existing policy to create a new policy. No command-line equivalent exists for this procedure.
  1. If necessary, start the SEAM Tool.
    See How to Start the SEAM Tool for more information.
    $ /usr/sbin/gkadmin
  2. Click the Policies tab.
  3. Select the policy in the list that you want to duplicate, then click Duplicate.
    The Policy Details panel is displayed. All the attributes of the selected policy are duplicated, except for the Policy Name field, which is empty.
  4. Specify a name for the duplicated policy in the Policy Name field.
    The policy name is mandatory. To make an exact duplicate of the policy you selected, skip to Step 6.
  5. Specify different values for the policy's attributes.
    Choose Context-Sensitive Help from the Help menu for information about the various attributes in this window. Or, go to Table 25–5 for all the policy attribute descriptions.
  6. Click Save to save the policy, or click Done.
