System Administration Guide: Security Services
exec_args Token
The exec_args token records the arguments to an exec() system call. The exec_args token has two fixed fields:
The remainder of this token is composed of count strings. The praudit -x command shows the fields of the exec_args token:
Note –
The exec_args token is output only when the argv audit policy option is active.
