System Administration Guide: Security Services
ipc_perm Token
The ipc_perm token contains a copy of the System V IPC access permissions. This token is added to audit records that are generated by IPC shared-memory events, IPC semaphore events, and IPC message events.
The ipc_perm token has eight fields:
The praudit -x command shows the fields of the ipc_perm token. The line is wrapped for display purposes.
<IPC_perm uid="jdoe" gid="staff" creator-uid="jdoe"
creator-gid="staff" mode="100600" seq="0" key="0x0"/>
The values are taken from the ipc_perm structure that is associated with the IPC object.
