System Administration Guide: Security Services
socket Token
The socket token contains information that describes an Internet socket. In some instances, the token has four fields:
The praudit command displays this instance of the socket token as follows:
In most instances, the token has eight fields:
Since the Solaris 8 release, the Internet address can be displayed in IPv4 format or IPv6 format. The IPv4 address uses 4 bytes. The IPv6 address uses 1 byte to describe the address type, and 16 bytes to describe the address.
The praudit command displays the socket token as follows:
The praudit -x command shows the fields of the socket token. The line is wrapped for display purposes.
<socket sock_domain="0x0002" sock_type="0x0002" lport="0x83cf"
laddr="example1" fport="0x2383" faddr="server1.Subdomain.Domain.COM"/>
