System Administration Guide: Security Services
Controlling Auditing Costs
Because auditing consumes system resources, you must control the degree of detail that is recorded. When you decide what to audit, consider the following costs of auditing:
Cost of Increased Processing Time of Audit Data
The cost of increased processing time is the least significant of the costs of auditing. The first reason is that auditing generally does not occur during computation-intensive tasks, such as image processing, complex calculations, and so forth. The other reason is that the cost for single-user systems is usually small enough to ignore.
Cost of Analysis of Audit Data
The cost of analysis is roughly proportional to the amount of audit data that is collected. The cost of analysis includes the time that is required to merge and review audit records. Cost also includes the time that is required to archive the records and keep the records in a safe place.
The fewer records that you generate, the less time that is required to analyze the audit trail. Upcoming sections, Cost of Storage of Audit Data and Auditing Efficiently, describe ways to audit efficiently. Efficient auditing reduces the amount of audit data, while still providing enough coverage to achieve your site's security goals.
Storage cost is the most significant cost of auditing. The amount of audit data depends on the following:
Because these factors vary from site to site, no formula can predetermine the amount of disk space to set aside for audit data storage. Use the following information as a guide:
