System Administration Guide: Security Services
audit_control File
The /etc/security/audit_control file on each system contains configuration information for the auditd daemon. The file enables every system to mount a remote audit file system to store their audit records.
You can specify five kinds of information in the audit_control file. Each line of information begins with a keyword.
For more information about the audit_control file, see the audit_control(4) man page. For information about the plugins, see Audit Plugins and the audit_binfile(5) and audit_syslog(5) man pages.
Example 31–2 Sample audit_control File
The following is a sample audit_control file for the system noddy. noddy uses two audit file systems on the audit server blinken, and a third audit file system that is mounted from the second audit server winken. The third file system is used only when the audit file systems on blinken become full or unavailable. The minfree value of 20 percent specifies that the warning script is run when the file systems are 80 percent full. The settings specify that logins and administrative operations are to be audited. The operations are audited for success and for failure. Failures of all types, except failures to create a file system object, are to be audited. Nonattributable events are also audited. The syslog audit log records fewer audit events. This log contains text summaries of failed logins and failed administrative operations.
In the Solaris 10 release, the dir and minfree lines are deprecated. In the following example, the plugin lines do not contain a line break.
naflags:lo,nt; p_minfree=20; p_dir=/var/audit/blinken/files,
/var/audit/blinken.1/files,/var/audit/winken; p_flags=-lo,-am
