System Administration Guide: Security Services
path_attr Token
The path_attr token contains access path information for an object. The access path specifies the sequence of attribute file objects below the path token object. Systems calls such as openat() access attribute files. For more information on attribute file objects, see the fsattr(5) man page.
The path_attr token contains the following fields:
The praudit command displays the path_attr token as follows:
path_attr,1,attr_file_name
