System Administration Guide: Security Services
Configuring the Audit Service in Zones (Tasks)
The audit service audits the entire system, including audit events in zones. A system that has installed non-global zones can audit all zones identically, or can control auditing per zone. For background, see Auditing on a System With Zones. To plan, see How to Plan Auditing in Zones.
ProcedureHow to Configure All Zones Identically for Auditing
This procedure enables audits every zone identically. This method requires the least computer overhead and administrative resources.
  1. Configure the global zone for auditing.
    1. Complete the tasks in Configuring Audit Files (Task Map).
    2. Complete the tasks in Configuring and Enabling the Audit Service (Task Map), with the following exceptions.
      • Do not enable perzone audit policy.
      • Do not enable the audit service. You enable the audit service after you have configured the non-global zones for auditing.
  2. Copy the audit configuration files from the global zone to every non-global zone.
    Copy any of the following files that you have edited: audit_class, audit_control, audit_event, audit_user. Do not copy audit_startup or audit_warn. You do not have to copy files that you have not edited.
    You have two options. As superuser, you can copy the files, or loopback mount the files. The non-global zone must be running.
    • Copy the files.
      1. From the global zone, list the /etc/security directory in the non-global zone.
        # ls /zone/zonename/etc/security/
      2. Copy the audit configuration files to the zone's /etc/security directory.
        # cp /etc/security/audit-file /zone/zonename/etc/security/audit-file
        Later, if you modify an audit configuration file in the global zone, you re-copy the file to the non-global zones.
    • Loopback mount the configuration files.
      1. From the global zone, halt the non-global zone.
        # zoneadm -z non-global-zone halt
      2. Create a read-only loopback mount for every audit configuration file that you modified in the global zone.
        # zonecfg -z non-global-zone
         add fs
            set special=/etc/security/audit-file
            set dir=/etc/security/audit-file
            set type=lofs
            add options [ro,nodevices,nosetuid]
            end
         exit
      3. To make the changes effective, boot the non-global zone.
        # zoneadm -z non-global-zone boot
        You can also reboot the system.
        Later, if you modify an audit configuration file in the global zone, you reboot the system to refresh the loopback-mounted files in the non-global zones.
Example 30–24 Loopback Mounting Audit Configuration Files
In this example, the system administrator has modified the audit_class, audit_event, audit_control, audit_user, audit_startup, and audit_warn files.
The audit_startup and audit_warn files are read in the global zone only, so do not have to be loopback mounted into the non-global zones.
On this system, machine1, the administrator has created two non-global zones, machine1–webserver and machine1–appserver. The administrator has finished customizing the audit configuration files. If the administrator later modifies the files, the system will be rebooted to make the changes effective.
# zoneadm -z machine1-webserver halt
# zoneadm -z machine1-appserver halt
# zonecfg -z machine1-webserver
 add fs
    set special=/etc/security/audit_class
    set dir=/etc/security/audit_class
    set type=lofs
    end
 add fs
    set special=/etc/security/audit_event
    set dir=/etc/security/audit_event
    set type=lofs
    end
 add fs
    set special=/etc/security/audit_control
    set dir=/etc/security/audit_control
    set type=lofs
    end
add fs
    set special=/etc/security/audit_user
    set dir=/etc/security/audit_user
    set type=lofs
    end
 exit
# zonecfg -z machine1-appserver
 add fs
    set type=lofs
    end
 exit
When the zones are rebooted, the audit configuration files are read-only in the zones.
ProcedureHow to Configure Per-Zone Auditing
This procedure enables separate zone administrators to control the audit service in their zone. For the complete list of policy options, see the auditconfig(1M) man page.
  1. In the global zone, configure auditing, but do not enable the audit service.
      • Add the perzone audit policy. For an example, see Example 30–18.
      • Do not enable the audit service. You enable the audit service after the non-global zones are configured for auditing.
  2. In each non-global zone, configure the audit files.
    Note –
    If you are planning to disable auditing in the non-global zone, you can skip this step. To disable auditing, see Example 30–25.
    2. Follow the procedures that are described in Configuring and Enabling the Audit Service (Task Map).
    3. Do not configure system-wide audit settings.
      Specifically, do not add the perzone or ahlt policy to the non-global zone's audit_startup file. And do not run the bsmconv command from the non-global zone.
    4. Enable auditing in your zone.
      When the global zone reboots after auditing is configured, auditing is automatically enabled in your zone.
      If the global zone administrator activates the perzone audit policy after the system is booted, individual zone administrators must enable auditing. For details, see Example 30–20.
  3. In the global zone, enable the audit service.
    For the procedure, see How to Enable the Audit Service.
Example 30–25 Disabling Auditing in a Non-Global Zone
This example works if the global zone has set the perzone audit policy. The zone administrator of the noaudit zone disables auditing for that zone. Because the administrator planned to disable auditing, she did not edit the audit configuration files.
noauditzone # svcadm disable svc:/system/auditd
