System Administration Guide: Security Services
Configuring Device Policy (Task Map)
The following task map points to device configuration procedures that are related to device policy.
For Instructions
View the device policy for the devices on your system
Lists the devices and their device policy.
How to View Device Policy
Require privilege for device use
Uses privileges to protect a device.
How to Change the Device Policy on an Existing Device
Remove privilege requirements from a device
Removes or lessens the privileges that are required to access a device.
Example 4–3
Audit changes in device policy
Records changes in device policy in the audit trail
How to Audit Changes in Device Policy
Access /dev/arp
Gets Solaris IP MIB-II information.
How to Retrieve IP MIB-II Information From a /dev/* Device
