System Administration Guide: Security Services
ProcedureHow to Retrieve IP MIB-II Information From a /dev/* Device
Applications that retrieve Solaris IP MIB-II information should open /dev/arp, not /dev/ip.
  1. Determine the device policy on /dev/ip and /dev/arp.
    % getdevpolicy /dev/ip /dev/arp
    /dev/ip
            read_priv_set=net_rawaccess
            write_priv_set=net_rawaccess
    /dev/arp
            read_priv_set=none
            write_priv_set=none
    Note that the net_rawaccess privilege is required for reading and writing to /dev/ip. No privileges are required for /dev/arp.
  2. Open /dev/arp and push the tcp and udp modules.
    No privileges are required. This method is equivalent to opening /dev/ip and pushing the arp, tcp and udp modules. Because opening /dev/ip now requires a privilege, the /dev/arp method is preferred.
