System Administration Guide: Security Services
Device Policy Commands
Device management commands administer the device policy on local files. Device policy can include privilege requirements. Only superuser or a role of equivalent capabilities can manage devices.
The following table lists the device management commands.
Table 4–1 Device Management Commands
Command
Purpose
Man Page
devfsadm
Administers devices and device drivers on a running system. Also loads device policy.
The devfsadm command enables the cleanup of dangling /dev links to disk, tape, port, audio, and pseudo devices. Devices for a named driver can also be reconfigured.
devfsadm(1M)
getdevpolicy
Displays the policy associated with one or more devices. This command can be run by any user.
getdevpolicy(1M)
add_drv
Adds a new device driver to a running system. Contains options to add device policy to the new device. Typically, this command is called in a script when a device driver is being installed.
add_drv(1M)
update_drv
Updates the attributes of an existing device driver. Contains options to update the device policy for the device. Typically, this command is called in a script when a device driver is being installed.
update_drv(1M)
rem_drv
Removes a device or device driver.
rem_drv(1M)
