System Administration Guide: Security Services
ProcedureHow to Allocate a Device
Before You Begin
Device allocation must be enabled, as described in How to Make a Device Allocatable. If authorization is required, the user must have the authorization.
  1. Allocate the device.
    Specify the device by device name.
    % allocate device-name
  2. Verify that the device is allocated.
    Run the identical command.
    allocate. Device already allocated.
Example 4–7 Allocating a Microphone
In this example, the user jdoe allocates a microphone, audio.
% whoami
% allocate audio
Example 4–8 Allocating a Printer
In this example, a user allocates a printer. No one else can print to printer-1 until the user deallocates it, or until the printer is forcibly allocated to another user.
% allocate /dev/lp/printer-1
For an example of forcible deallocation, see Forcibly Deallocating a Device.
Example 4–9 Allocating a Tape Drive
In this example, the user jdoe allocates a tape drive, st0.
% whoami
% allocate st0
If the allocate command cannot allocate the device, an error message is displayed in the console window. For a list of allocation error messages, see the allocate(1) man page.
