System Administration Guide: Security Services
Using the Key Management Framework (Tasks)
This section describes how to use the pktool command to manage your public key objects, such as passwords, passphrases, files, keystores, certificates, and CRLs.
ProcedureHow to Create a Certificate by Using the pktool gencert Command
This procedure creates a self-signed certificate and stores the certificate in the PKCS #11 keystore. As a part of this operation, an RSA public/private key pair is also created. The private key is stored in the keystore with the certificate.
  1. Generate a self-signed certificate.
    % pktool gencert [keystore=keystore] label=label-name \
    subject=subject-DN serial=hex-serial-number
    keystore=keystore
    Specifies the keystore by type of public key object. The value can be nss, pkcs11, or ssl. This keyword is optional.
    label=label-name
    Is a unique name that the issuer gives to the certificate.
    subject=subject-DN
    Is the distinguished name for the certificate.
    Is the serial number in hexadecimal format. The issuer of the certificate chooses the number, such as 0x0102030405.
  2. Verify the contents of the keystore.
    % pktool list
    Found number certificates.
    1. (X.509 certificate)
          Label:  label-name
          ID: Fingerprint that binds certificate to private key
          Subject: subject-DN
          Issuer:  distinguished-name
          Serial:  hex-serial-number
    n. ...
    This command lists all certificates in the keystore. In the following example, the keystore contains one certificate only.
Example 15–1 Creating a Self-Signed Certificate by Using pktool
In the following example, a user at My Company creates a self-signed certificate and stores the certificate in a keystore for PKCS #11 objects. The keystore is initially empty. If the keystore has not been initialized, the PIN for the softtoken is changeme.
% pktool gencert keystore=pkcs11 label="My Cert" \
subject="C=US, O=My Company, OU=Security Engineering Group, CN=MyCA" \
serial=0x000000001
Enter pin for Sun Software PKCS#11 softtoken:Type PIN for token
% pktool list
Found 1 certificates.
      Label: My Cert
      Subject: C=US, O=My Company, OU=Security Engineering Group, CN=MyCA
      Issuer: C=US, O=My Company, OU=Security Engineering Group, CN=MyCA
      Serial: 0x01
ProcedureHow to Import a Certificate Into Your Keystore
This procedure describes how to import a file with PKI information that is encoded with PEM or with raw DER into your keystore. For an export procedure, see Example 15–4.
  1. Import the certificate.
    % pktool import keystore=keystore infile=infile-name label=label-name
  2. If you are importing private PKI objects, provide passwords when prompted.
    1. At the prompt, provide the password for the file.
      If you are importing PKI information that is private, such as an export file in PKCS #12 format, the file requires a password. The creator of the file that you are importing provides you with the PKCS #12 password.
      Enter password to use for accessing the PKCS12 file:Type PKCS #12 password
    2. At the prompt, type the password for your keystore.
      Enter pin for Sun Software PKCS#11 softtoken: Type PIN for token
  3. Verify the contents of the keystore.
    % pktool list
          Label:  label-name
          Subject: subject-DN
    2. ...
Example 15–2 Importing a PKCS #12 File Into Your Keystore
In the following example, the user imports a PKCS #12 file from a third party. The pktool import command extracts the private key and the certificate from the gracedata.p12 file, and stores them in the user's preferred keystore.
% pktool import keystore=pkcs11 infile=gracedata.p12 label=GraceCert
Found 1 certificate(s) and 1 key(s) in gracedata.p12
% pktool list
        Label: GraceCert
        Serial: 0x01
Example 15–3 Importing an X.509 Certificate Into Your Keystore
In the following example, the user imports an X.509 certificate in PEM format into the user's preferred keystore. This public certificate is not protected with a password. The user's public keystore is also not protected by a password.
% pktool import keystore=pkcs11 infile=somecert.pem label="TheirCompany Root Cert"
% pktool list
        Label: TheirCompany Root Cert
        Subject: C=US, O=TheirCompany, OU=Security, CN=TheirCompany Root CA
        Issuer: C=US, O=TheirCompany, OU=Security, CN=TheirCompany Root CA
        Serial: 0x01
ProcedureHow to Export a Certificate and Private Key in PKCS #12 Format
You can create a file in PKCS #12 format to export private keys and their associated X.509 certificate to other systems. Access to the file is protected by a password.
  1. Find the certificate to export.
    % pktool list
          Label:  label-name
          Subject: subject-DN
    2. ...
  2. Export the keys and certificate.
    Use the keystore and label from the pktool list command. Provide a file name for the export file. When the name contains a space, surround the name with double quotes.
    % pktool export keystore=keystore outfile=outfile-name label=label-name
  3. Protect the export file with a password.
    At the prompt, type the current password for the keystore. At this point, you create a password for the export file. The receiver must provide this password when importing the file.
    Enter password to use for accessing the PKCS12 file:Create PKCS #12 password
    Tip –
    Send the password separately from the export file. Best practice suggests that you provide the password out of band, such as during a telephone call.
Example 15–4 Exporting a Certificate and Private Key in PKCS #12 Format
In the following example, a user exports the private keys with their associated X.509 certificate into a standard PKCS #12 file. This file can be imported into other keystores. The PKCS #11 password protects the source keystore. The PKCS #12 password is used to protect private data in the PKCS #12 file. This password is required to import the file.
% pktool list
      Label: My Cert
      Serial: 0x01
% pktool export keystore=pkcs11 outfile=mydata.p12 label="My Cert"
The user then telephones the recipient and provides the PKCS #12 password.
ProcedureHow to Generate a Passphrase by Using the pktool setpin Command
You can generate a passphrase for an object in a keystore, and for the keystore itself. The passphrase is required to access the object or keystore. For an example of generating a passphrase for an object in a keystore, see Example 15–4.
  1. Generate a passphrase for access to a keystore.
    % pktool setpin keystore=nss|pkcs11 dir=directory
  2. Answer the prompts.
    If the keystore does not have a password already set, press the Return key to create the password.
    Enter current token passphrase:Press the Return key
    Create new passphrase:Type the passphrase that you want to use
    Re-enter new passphrase:Retype the passphrase
    Passphrase changed.
    The keystore is now protected by passphrase. If you lose the passphrase, you lose access to the objects in the keystore.
Example 15–5 Protecting a Keystore With a Passphrase
The following example shows how to set the passphrase for an NSS database. Because no passphrase has been created, the user presses the Return key at the first prompt.
% pktool setpin keystore=nss dir=/var/nss
Create new passphrase:    has8n0NdaH
Re-enter new passphrase:  has8n0NdaH
Passphrase changed.
