Solaris role-based access control (RBAC) and privileges provide a more secure alternative to superuser. This chapter provides overview information about RBAC and about privileges.
The following is a list of the overview information in this chapter.
Solaris 10 8/07: Starting in this release, the project.max-locked-memory and zone.max-locked-memory resource controls were introduced. If the PRIV_PROC_LOCK_MEMORY privilege is assigned to a user or non-global zone, these resource controls can be set to prevent the user or zone from locking all memory. For more discussion, see Privileges and System Resources.
Solaris 10 10/08: In this release, the solaris.admin.usermgr authorizations have been reorganized to support separation of duty, a security requirement at highly secure installations. To satisfy separation of duty, two accounts are required to create a user account. To configure the software for this requirement, see Create Rights Profiles That Enforce Separation of Duty in Oracle Solaris Trusted Extensions Configuration Guide. Also in this release, this guide describes how to change the password of a role in How to Change the Password of a Role.
Solaris 10 9/10: In this release, the net_access privilege is added to the basic set of privileges. For a description of the privilege, see the privileges(5) man page.
Role-based access control (RBAC) is a security feature for controlling user access to tasks that would normally be restricted to superuser. By applying security attributes to processes and to users, RBAC can divide up superuser capabilities among several administrators. Process rights management is implemented through privileges. User rights management is implemented through RBAC.
For a discussion of process rights management, see Privileges (Overview).
For information on RBAC tasks, see Chapter 9, Using Role-Based Access Control (Tasks).
For reference information, see Chapter 10, Role-Based Access Control (Reference).
In conventional UNIX systems, the root user, also referred to as superuser, is all-powerful. Programs that run as root, or setuid programs, are all-powerful. The root user has the ability to read and write to any file, run all programs, and send kill signals to any process. Effectively, anyone who can become superuser can modify a site's firewall, alter the audit trail, read confidential records, and shut down the entire network. A setuid program that is hijacked can do anything on the system.
Role-based access control (RBAC) provides a more secure alternative to the all-or-nothing superuser model. With RBAC, you can enforce security policy at a more fine-grained level. RBAC uses the security principle of least privilege. Least privilege means that a user has precisely the amount of privilege that is necessary to perform a job. Ordinary users have enough privilege to use their applications, check the status of their jobs, print files, create new files, and so on. Capabilities beyond ordinary user capabilities are grouped into rights profiles. Users who are expected to do jobs that require some of the capabilities of superuser assume a role that includes the appropriate rights profile.
RBAC collects superuser capabilities into rights profiles. These rights profiles are assigned to special user accounts that are called roles. A user can then assume a role to do a job that requires some of superuser's capabilities. Predefined rights profiles are supplied with Solaris software. You create the roles and assign the profiles.
Rights profiles can provide broad capabilities. For example, the Primary Administrator rights profile is equivalent to superuser. Rights profiles can also be narrowly defined. For example, the Cron Management rights profile manages at and cron jobs. When you create roles, you can decide to create roles with broad capabilities, or roles with narrow capabilities, or both.
In the RBAC model, superuser creates one or more roles. The roles are based on rights profiles. Superuser then assigns the roles to users who are trusted to perform the tasks of the role. Users log in with their user name. After login, users assume roles that can run restricted administrative commands and graphical user interface (GUI) tools.
The flexibility in setting up roles enables a variety of security policies. Although no roles are shipped with the Solaris Operating System (Solaris OS), three recommended roles can easily be configured. The roles are based on rights profiles of the same name:
Primary Administrator – A powerful role that is equivalent to the root user, or superuser.
System Administrator – A less powerful role for administration that is not related to security. This role can manage file systems, mail, and software installation. However, this role cannot set passwords.
Operator – A junior administrator role for operations such as backups and printer management.
These three roles do not have to be implemented. Roles are a function of an organization's security needs. Roles can be set up for special-purpose administrators in areas such as security, networking, or firewall administration. Another strategy is to create a single powerful administrator role along with an advanced user role. The advanced user role would be for users who are permitted to fix portions of their own systems.
The superuser model and the RBAC model can co-exist. The following table summarizes the gradations from superuser to restricted ordinary user that are possible in the RBAC model. The table includes the administrative actions that can be tracked in both models. For a summary of the effect of privileges alone on a system, see Table 8–2.
Table 8–1 Superuser Model Versus RBAC With Privileges Model
User Capabilities on a System |
Superuser Model |
RBAC Model |
Can become superuser with full superuser capability |
Yes |
Yes |
Can log in as a user with full user capabilities |
Yes |
Yes |
Can become superuser with limited capabilities |
No |
Yes |
Can log in as a user, and have superuser capabilities, sporadically |
Yes, with setuid programs only |
Yes, with setuid programs and with RBAC |
Can log in as a user with administrative capabilities, but without full superuser capability |
No |
Yes, with RBAC and with directly-assigned privileges and authorizations |
Can log in as a user with fewer capabilities than an ordinary user |
No |
Yes, with RBAC and with removed privileges |
Can track superuser actions |
Yes, by auditing the su command |
Yes, by auditing profile shell commands Also, if root user is disabled, the name of the user who has assumed the root role is in the audit trail |
The RBAC model in the Solaris OS introduces the following elements:
Authorization – A permission that enables a user or role to perform a class of actions that could affect security. For example, security policy at installation gives ordinary users the solaris.device.cdrw authorization. This authorization enables users to read and write to a CD-ROM device. For a list of authorizations, see the /etc/security/auth_attr file.
Privilege – A discrete right that can be granted to a command, a user, a role, or a system. Privileges enable a process to succeed. For example, the proc_exec privilege allows a process to call execve(). Ordinary users have basic privileges. To see your basic privileges, run the ppriv -vl basic command.
Security attributes – An attribute that enables a process to perform an operation. In a typical UNIX environment, a security attribute enables a process to perform an operation that is otherwise forbidden to ordinary users. For example, setuid and setgid programs have security attributes. In the RBAC model, operations that ordinary users perform might require security attributes. In addition to setuid and setgid programs, authorizations and privileges are also security attributes in the RBAC model. For example, a user with the solaris.device.allocate authorization can allocate a device for exclusive use. A process with the sys_time privilege can manipulate system time.
Privileged application – An application or command that can override system controls by checking for security attributes. In a typical UNIX environment and in the RBAC model, programs that use setuid and setgid are privileged applications. In the RBAC model, programs that require privileges or authorizations to succeed are also privileged applications. For more information, see Privileged Applications and RBAC.
Rights profile – A collection of administrative capabilities that can be assigned to a role or to a user. A rights profile can consist of authorizations, of commands with security attributes, and of other rights profiles. Rights profiles offer a convenient way to group security attributes.
Role – A special identity for running privileged applications. The special identity can be assumed by assigned users only. In a system that is run by roles, superuser is unnecessary. Superuser capabilities are distributed to different roles. For example, in a two-role system, security tasks would be handled by a security role. The second role would handle system administration tasks that are not security-related. Roles can be more fine-grained. For example, a system could include separate administrative roles for handling the cryptographic framework, printers, system time, file systems, and auditing.
The following figure shows how the RBAC elements work together.
In RBAC, roles are assigned to users. When a user assumes a role, the capabilities of the role are available. Roles get their capabilities from rights profiles. Rights profiles can contain authorizations, privileged commands, and other supplementary rights profiles. Privileged commands are commands that execute with security attributes.
The following figure uses the Operator role, the Operator rights profile, and the Printer Management rights profile to demonstrate RBAC relationships.
The Operator role is used to maintain printers and to perform media backup. The role is assigned to the user jdoe. jdoe can assume the role by switching to the role, and then supplying the role password.
The Operator rights profile has been assigned to the Operator role. The Operator rights profile contains two supplementary profiles, Printer Management and Media Backup. The supplementary profiles reflect the role's primary tasks.
The Printer Management rights profile is for managing printers, print daemons, and spoolers. Three authorizations are included in the Printer Management rights profile: solaris.admin.printer.read, solaris.admin.printer.delete, and solaris.admin.printer.modify. These authorizations enable roles and users to manipulate information in the printer queue. The Printer Management rights profile also includes a number of commands with security attributes, such as /usr/sbin/lpshut with euid=lp and /usr/ucb/lpq with euid=0.
An authorization is a discrete right that can be granted to a role or to a user. Authorizations enforce policy at the user application level. Authorizations can be assigned directly to a role or to a user. Typically, authorizations are included in a rights profile. The rights profile is then included in a role, and the role is assigned to a user. For an example, see Figure 8–2.
RBAC-compliant applications can check a user's authorizations prior to granting access to the application or specific operations within the application. This check replaces the check in conventional UNIX applications for UID=0. For more information on authorizations, see the following sections:
Privileges enforce security policy in the kernel. The difference between authorizations and privileges concerns the level at which the security policy is enforced. Without the proper privilege, a process can be prevented from performing privileged operations by the kernel. Without the proper authorizations, a user might be prevented from using a privileged application or from performing security-sensitive operations within a privileged application. For a fuller discussion of privileges, see Privileges (Overview).
Applications and commands that can override system controls are considered privileged applications. Security attributes such as UID=0, privileges, and authorizations make an application privileged.
Privileged applications that check for root (UID=0) or some other special UID or GID have long existed in the UNIX environment. The rights profile mechanism enables you to isolate commands that require a specific ID. Instead of changing the ID on a command that anyone can access, you can place the command with execution security attributes in a rights profile. A user or role with that rights profile can then run the program without having to become superuser.
IDs can be specified as real or effective. Assigning effective IDs is preferred over assigning real IDs. Effective IDs are equivalent to the setuid feature in the file permission bits. Effective IDs also identify the UID for auditing. However, because some shell scripts and programs require a real UID of root, real UIDs can be set as well. For example, the pkgadd command requires a real rather than an effective UID. If an effective ID is not sufficient to run a command, you need to change the ID to a real ID. For the procedure, see How to Create or Change a Rights Profile.
Privileged applications can check for the use of privileges. The RBAC rights profile mechanism enables you to specify the privileges for specific commands. Instead of requiring superuser capabilities to use an application or command, you can isolate the command with execution security attributes in a rights profile. A user or role with that rights profile can then run the command with just the privileges that the command requires to succeed.
Commands that check for privileges include the following:
Kerberos commands, such as kadmin, kprop, and kdb5_util
Network commands, such as ifconfig, routeadm, and snoop
File and file system commands, such as chmod, chgrp, and mount
Commands that control processes, such as kill, pcred, and rcapadm
To add commands with privileges to a rights profile, see How to Create or Change a Rights Profile. To determine what commands check for privileges in a particular profile, see Determining Your Assigned Privileges.
The Solaris OS additionally provides commands that check authorizations. By definition, the root user has all authorizations. Therefore, the root user can run any application. Applications that check for authorizations include the following:
The entire Solaris Management Console suite of tools
Audit administration commands, such as auditconfig and auditreduce
Printer administration commands, such as lpadmin and lpfilter
The batch job-related commands, such as at, atq, batch, and crontab
Device-oriented commands, such as allocate, deallocate, list_devices, and cdrw.
To test a script or program for authorizations, see Example 9–24. To write a program that requires authorizations, see About Authorizations in Oracle Solaris Security for Developers Guide.
A rights profile is a collection of system overrides that can be assigned to a role or user. A rights profile can include authorizations, commands with assigned security attributes, and other rights profiles. Rights profile information is split between the prof_attr and exec_attr databases. The rights profile name and authorizations are in the prof_attr database. The rights profile name and the commands with assigned security attributes are in the exec_attr database.
For more information on rights profiles, see the following sections:
A role is a special type of user account from which you can run privileged applications. Roles are created in the same general manner as user accounts. Roles have a home directory, a group assignment, a password, and so on. Rights profiles and authorizations give the role administrative capabilities. Roles cannot inherit capabilities from other roles or other users. Discrete roles parcel out superuser capabilities, and thus enable more secure administrative practices.
When a user assumes a role, the role's attributes replace all user attributes. Role information is stored in the passwd, shadow, and user_attr databases. Role information can be added to the audit_user database. For detailed information on setting up roles, see the following sections:
A role can be assigned to more than one user. All users who can assume the same role have the same role home directory, operate in the same environment, and have access to the same files. Users can assume roles from the command line by running the su command and supplying the role name and password. Users can also assume a role in the Solaris Management Console tool.
A role cannot log in directly. A user logs in, and then assumes a role. Having assumed a role, the user cannot assume another role without first exiting their current role. Having exited the role, the user can then assume another role.
You can prevent anonymous root login by changing the root user into a role, as shown in How to Make root User Into a Role. If the profile shell command, pfexec, is being audited, the audit trail contains the login user's real UID, the roles that the user has assumed, and the actions that the role performed. To audit the system or a particular user for role operations, see How to Audit Roles.
No predefined roles are shipped with Solaris software. However, the rights profiles that ship with the software are designed to map to roles. For example, the Primary Administrator rights profile can be used to create the Primary Administrator role.
To configure the Primary Administrator role, see Using the Solaris Management Tools With RBAC (Task Map) in System Administration Guide: Basic Administration.
To configure other roles, see How to Create and Assign a Role by Using the GUI.
To create roles on the command line, see Managing RBAC (Task Map).
Roles can run privileged applications from the Solaris Management Console launcher or from a profile shell. A profile shell is a special shell that recognizes the security attributes that are included in a rights profile. Profile shells are launched when the user runs the su command to assume a role. The profile shells are pfsh, pfcsh, and pfksh. The shells correspond to Bourne shell (sh), C shell (csh), and Korn shell (ksh), respectively. Many shells have a profile shell counterpart. For example, the profile shell counterparts to the Bourne shell (sh), C shell (csh), and Korn shell (ksh) are the pfsh, pfcsh, and pfksh shells, respectively. For the list of profile shells, see the pfexec(1) man page.
Users who have been directly assigned a rights profile must invoke a profile shell to run the commands with security attributes. For usability and security considerations, see Security Considerations When Directly Assigning Security Attributes.
All commands that are executed in a profile shell can be audited. For more information, see How to Audit Roles.
Name service scope is an important concept for understanding RBAC. The scope of a role might be limited to an individual host. Alternatively, the scope might include all hosts that are served by a name service such as NIS, NIS+, or LDAP. The name service scope for a system is specified in the file /etc/nsswitch.conf. A lookup stops at the first match. For example, if a rights profile exists in two name service scopes, only the entries in the first name service scope are used. If files is the first match, then the scope of the role is limited to the local host.
Typically, a user obtains administrative capabilities through a role. Authorizations and privileged commands are grouped into a rights profile. The rights profile is included in a role, and the role is assigned to a user.
Direct assignment of rights profiles and security attributes is also possible:
Rights profiles, privileges, and authorizations can be assigned directly to users.
Privileges and authorizations can be assigned directly to roles.
However, direct assignment is not a secure practice. Users and roles with a directly assigned privilege could override security policy wherever this privilege is required by the kernel. When a privilege is a security attribute of a command in a rights profile, that privilege is available only for that command by someone who has that rights profile. The privilege is not available for other commands that the user or role might run.
Since authorizations act at the user level, direct assignment of authorizations can be less dangerous than direct assignment of privileges. However, authorizations can enable a user to perform highly secure tasks, such as delegate device administration.
A rights profile that is assigned directly to a user presents usability problems more than security problems. The commands with security attributes in the rights profile can only succeed in a profile shell. The user must open a profile shell, then type the commands. A role that is assigned a rights profile gets a profile shell automatically. Therefore, the commands succeed in the role's shell.
Rights profiles provide an extensible, clean way to group security characteristics for particular administrative tasks.
Process rights management enables processes to be restricted at the command, user, role, or system level. The Solaris OS implements process rights management through privileges. Privileges decrease the security risk that is associated with one user or one process having full superuser capabilities on a system. Privileges and RBAC provide a compelling alternative model to the traditional superuser model.
For information on RBAC, see Role-Based Access Control (Overview).
For information on how to administer privileges, see Chapter 11, Privileges (Tasks).
For reference information on privileges, see Chapter 12, Privileges (Reference).
A privilege is a discrete right that a process requires to perform an operation. The right is enforced in the kernel. A program that operates within the bounds of the Solaris basic set of privileges operates within the bounds of the system security policy. setuid programs are examples of programs that operate outside the bounds of the system security policy. By using privileges, programs eliminate the need for calls to setuid.
Privileges discretely enumerate the kinds of operations that are possible on a system. Programs can be run with the exact privileges that enable the program to succeed. For example, a program that sets the date and writes the date to an administrative file might require the file_dac_write and sys_time privileges. This capability eliminates the need to run any program as root.
Historically, systems have not followed the privilege model. Rather, systems used the superuser model. In the superuser model, processes run as root or as a user. User processes were limited to acting on the user's directories and files. root processes could create directories and files anywhere on the system. A process that required creation of a directory outside the user's directory would run with a UID=0, that is, as root. Security policy relied on DAC, discretionary access control, to protect system files. Device nodes were protected by DAC. For example, devices owned by group sys could be opened only by members of group sys.
However, setuid programs, file permissions, and administrative accounts are vulnerable to misuse. The actions that a setuid process is permitted are more numerous than the process requires to complete its operation. A setuid program can be compromised by an intruder who then runs as the all-powerful root user. Similarly, any user with access to the root password can compromise the entire system.
In contrast, a system that enforces policy with privileges allows a gradation between user capabilities and root capabilities. A user can be granted privileges to perform activities that are beyond the capabilities of ordinary users, and root can be limited to fewer privileges than root currently possesses. With RBAC, a command that runs with privileges can be isolated in a rights profile and assigned to one user or role. Table 8–1 summarizes the gradation between user capabilities and root capabilities that the RBAC plus privileges model provides.
The privilege model provides greater security than the superuser model. Privileges that have been removed from a process cannot be exploited. Process privileges prevent a program or administrative account from gaining access to all capabilities. Process privileges can provide an additional safeguard for sensitive files, where DAC protections alone can be exploited to gain access.
Privileges, then, can restrict programs and processes to just the capabilities that the program requires. This capability is called the principle of least privilege. On a system that implements least privilege, an intruder who captures a process has access to only those privileges that the process has. The rest of the system cannot be compromised.
Privileges are logically grouped on the basis of the area of the privilege.
FILE privileges – Privileges that begin with the string file operate on file system objects. For example, the file_dac_write privilege overrides discretionary access control when writing to files.
IPC privileges – Privileges that begin with the string ipc override IPC object access controls. For example, the ipc_dac_read privilege enables a process to read remote shared memory that is protected by DAC.
NET privileges – Privileges that begin with the string net give access to specific network functionality. For example, the net_rawaccess privilege enables a device to connect to the network.
PROC privileges – Privileges that begin with the string proc allow processes to modify restricted properties of the process itself. PROC privileges include privileges that have a very limited effect. For example, the proc_clock_highres privilege enables a process to use high resolution timers.
SYS privileges – Privileges that begin with the string sys give processes unrestricted access to various system properties. For example, the sys_linkdir privilege enables a process to make and break hard links to directories.
Some privileges have a limited effect on the system, and some have a broad effect. The definition of the proc_taskid privilege indicates its limited effect:
proc_taskid Allows a process to assign a new task ID to the calling process. |
The definition of the file_setid privilege indicates its broad effect:
net_rawaccess Allow a process to have direct access to the network layer. |
The privileges(5) man page provides descriptions of every privilege. The command ppriv -lv prints a description of every privilege to standard out.
A system that has privileges has several visible differences from a system that does not have privileges. The following table lists some of the differences.
Table 8–2 Visible Differences Between a System With Privileges and a System Without Privileges
Starting in the Solaris 10 8/07 release, the project.max-locked-memory and zone.max-locked-memory resource controls can be used to limit the memory consumption of processes that are assigned the PRIV_PROC_LOCK_MEMORY privilege. This privilege allows a process to lock pages in physical memory.
If you assign the PRIV_PROC_LOCK_MEMORY privilege to a rights profile, you can give the processes that have this privilege the ability to lock all memory. As a safeguard, set a resource control to prevent the user of the privilege from locking all memory. For privileged processes that run in a non-global zone, set the zone.max-locked-memory resource control. For privileged processes that run on a system, create a project and set the project.max-locked-memory resource control. For information about these resource controls, see Chapter 6, Resource Controls (Overview), in System Administration Guide: Oracle Solaris Containers-Resource Management and Oracle Solaris Zones and Chapter 17, Non-Global Zone Configuration (Overview), in System Administration Guide: Oracle Solaris Containers-Resource Management and Oracle Solaris Zones.
Every process has four sets of privileges that determine whether a process can use a particular privilege. The kernel automatically calculates the effective set of privileges. You can modify the initial inheritable set of privileges. A program that is coded to use privileges can reduce the program's permitted set of privileges. You can shrink the limit set of privileges.
Effective privilege set, or E – Is the set of privileges that is currently in effect. A process can add privileges that are in the permitted set to the effective set. A process can also remove privileges from E.
Permitted privilege set, or P – Is the set of privileges that is available for use. Privileges can be available to a program from inheritance or through assignment. An execution profile is one way to assign privileges to a program. The setuid command assigns all privileges that root has to a program. Privileges can be removed from the permitted set, but privileges cannot be added to the set. Privileges that are removed from P are automatically removed from E.
A privilege-aware program removes the privileges that a program never uses from the program's permitted set. In this way, unnecessary privileges cannot be exploited by the program or a malicious process. For more information on privilege-aware programs, see Chapter 2, Developing Privileged Applications, in Oracle Solaris Security for Developers Guide.
Inheritable privilege set, or I – Is the set of privileges that a process can inherit across a call to exec. After the call to exec, the permitted and the effective sets are equal, except in the special case of a setuid program.
For a setuid program, after the call to exec, the inheritable set is first restricted by the limit set. Then, the set of privileges that were inherited (I), minus any privileges that were in the limit set (L), are assigned to P and E for that process.
Limit privilege set, or L – Is the outside limit of what privileges are available to a process and its children. By default, the limit set is all privileges. Processes can shrink the limit set but can never extend the limit set. L is used to restrict I. Consequently, L restricts P and E at the time of exec.
If a user has been assigned a profile that includes a program that has been assigned privileges, the user can usually run that program. On an unmodified system, the program's assigned privileges are within the user's limit set. The privileges that have been assigned to the program become part of the user's permitted set. To run the program that has been assigned privileges, the user must run the program from a profile shell.
The kernel recognizes a basic privilege set. On an unmodified system, each user's initial inheritable set equals the basic set at login. You can modify the user's initial inheritable set. You cannot modify the basic set.
On an unmodified system, a user's privilege sets at login would appear similar to the following:
E (Effective): basic I (Inheritable): basic P (Permitted): basic L (Limit): all |
Therefore, at login, all users have the basic set in their inheritable set, their permitted set, and their effective set. A user's limit set contains all privileges. To put more privileges in the user's effective set, you must assign a rights profile to the user. The rights profile would include commands to which you have added privileges. You can also assign privileges directly to the user or role, though such privilege assignment can be risky. For a discussion of the risks, see Security Considerations When Directly Assigning Security Attributes.
Processes can inherit privileges. Or, processes can be assigned privileges. A process inherits privileges from its parent process. At login, the user's initial inheritable set of privileges determines what privileges are available to the user's processes. All child processes of the user's initial login inherit that set.
You can also directly assign privileges to programs, users, and roles. When a program requires privileges, you assign the privileges to the program's executable in a rights profile. Users or roles that are permitted to run the program are assigned the profile that includes the program. At login or when a profile shell is entered, the program runs with privilege when the program's executable is typed in the profile shell. For example, a role that includes the Object Access Management profile is able to run the chmod command with the file_chown privilege.
When a role or user runs a program that has been directly assigned an additional privilege, the assigned privilege is added to the role or user's inheritable set. Child processes of the program that was assigned privileges inherit the privileges of the parent. If the child process requires more privileges than the parent process, the child process must be directly assigned those privileges.
Programs that are coded to use privileges are called privilege-aware programs. A privilege-aware program turns on the use of privilege and turns off the use of privilege during program execution. To succeed in a production environment, the program must be assigned the privileges that the program turns on and off.
For examples of privilege-aware code, see Chapter 2, Developing Privileged Applications, in Oracle Solaris Security for Developers Guide. To assign privileges to a program that requires privileges, see How to Add Privileges to a Command.
You, in your capacity as system administrator, are responsible for assigning privileges. Typically, you assign the privilege to a command in a rights profile. The rights profile is then assigned to a role or to a user. The Solaris Management Console provides the graphical user interface (GUI) to assign privileges. Privileges can also be assigned by using commands such as smuser and smrole. For more information on how to use the GUI to assign privileges, see Chapter 9, Using Role-Based Access Control (Tasks).
Privileges can also be assigned directly to a user. If you trust a subset of users to use a privilege responsibly throughout their sessions, you can assign the privilege directly. Good candidates for direct assignment are privileges that have a limited effect, such as proc_clock_highres. Poor candidates for direct assignment are privileges that have far-reaching effects, such as file_dac_write.
Privileges can also be denied to a user or to a system. Care must be taken when removing privileges from the initial inheritable set or the limit set of a user or a system.
Users and roles have an inheritable set of privileges, and a limit set of privileges. The limit set cannot be expanded, since the limit set is initially all privileges. The initial inheritable set can be expanded for users, roles, and systems. A privilege that is not in the inheritable set can also be assigned to a process.
The assignment of privileges per process is the most precise way to add privileges. You can expand the number of privileged operations that a user can perform by enabling the user to assume a role. The role would be assigned profiles that include commands with added privileges. When the user assumes the role, the user gets the role's profile shell. By typing in the role's shell, the commands in the role's profiles execute with the added privileges.
You can also assign a profile to the user rather than to a role that the user assumes. The profile would include commands with added privileges. When the user opens a profile shell, such as pfksh, the user can execute the commands in the user's profile with privilege. In a regular shell, the commands do not execute with privilege. The privileged process can only execute in a privileged shell.
To expand the initial inheritable set of privileges for users, roles, or systems is a riskier way to assign privileges. All privileges in the inheritable set are in the permitted and effective sets. All commands that the user or role types in a shell can use the directly assigned privileges. Directly assigned privileges enable a user or role to easily perform operations that can be outside the bounds of their administrative responsiblities.
When you add to the initial inheritable set of privileges on a system, all users who log on to the system have a larger set of basic privileges. Such direct assignment enables all users of the system to easily perform operations that are probably outside the bounds of ordinary users.
By removing privileges, you can prevent users and roles from performing particular tasks. You can remove privileges from the initial inheritable set, and from the limit set. You should carefully test removal of privileges before you distribute an initial inheritable set or a limit set that is smaller than the default set. By removing privileges from the initial inheritable set, you might prevent users from logging in. When privileges are removed from the limit set, a legacy setuid program might fail because the program requires a privilege that was removed.
Scripts are executables, like commands. Therefore, in a rights profile, you can add privileges to a script just as you can add privileges to a command. The script runs with the added privileges when a user or role who has been assigned the profile executes the script in a profile shell. If the script contains commands that require privileges, the commands with added privileges should also be in the profile.
Privilege-aware programs can restrict privileges per process. Your job with a privilege-aware program is to assign the executable just the privileges that the program needs. You then test the program to see that the program succeeds in performing its tasks. You also check that the program does not abuse its use of privileges.
The privilege model uses privileges to protect system interfaces that are protected by file permissions alone in the superuser model. In a system with privileges, file permissions are too weak to protect the interfaces. A privilege such as proc_owner could override file permissions and then give full access to all of the system.
Therefore, ownership of the device directory is not sufficient to open a device. For example, members of the group sys are no longer automatically allowed to open the /dev/ip device. The file permissions on /dev/ip are 0666, but the net_rawaccess privilege is required to open the device.
Device policy is controlled by privileges. The getdevpolicy command displays the device policy for every device. The device configuration command, devfsadm, installs the device policy. The devfsadm command binds privilege sets with open for reading or writing of devices. For more information, see the getdevpolicy(1M) and devfsadm(1M) man pages.
Device policy allows you more flexibility in granting permission to open devices. You can require different privileges or more privileges than the default device policy. The privilege requirements can be modified for the device policy and for the driver proper. You can modify the privileges when installing, adding, or updating a device driver.
The add_drv and update_drv commands can modify device policy entries and driver-specific privileges. You must be running a process with the full set of privileges to change the device policy. For more information, see the add_drv(1M) and update_drv(1M) man pages.
The Solaris OS provides tools to debug privilege failure. The ppriv command and the truss command provide debugging output. For examples, see the ppriv(1) man page. For a procedure, see How to Determine Which Privileges a Program Requires.
