System Administration Guide: Security Services
Managing and Using Privileges (Task Map)
The following task map points to task maps for managing privileges and for using privileges.
Task
Description
For Instructions
Use privileges at your site
Involves assigning, removing, adding, and debugging the use of privileges.
Managing Privileges (Task Map)
Use privileges when you run a command
Involves using the privileges that have been assigned to you.
Determining Your Privileges (Task Map)
