System Administration Guide: Security Services
ProcedureHow to Prevent the Use of a User-Level Mechanism
If some of the cryptographic mechanisms from a library provider should not be used, you can remove selected mechanisms. This procedure uses the DES mechanisms in the pkcs11_softtoken library as an example.
  1. Become superuser or assume a role that includes the Crypto Management rights profile.
    To create a role that includes the Crypto Management rights profile and assign the role to a user, see Example 9–7.
  2. List the mechanisms that are offered by a particular user-level software provider.
    % cryptoadm list -m provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so
    /usr/lib/security/$ISA/pkcs11_softtoken.so:
    CKM_DES_CBC,CKM_DES_CBC_PAD,CKM_DES_ECB,CKM_DES_KEY_GEN,
    CKM_DES3_CBC,CKM_DES3_CBC_PAD,CKM_DES3_ECB,CKM_DES3_KEY_GEN,
    CKM_AES_CBC,CKM_AES_CBC_PAD,CKM_AES_ECB,CKM_AES_KEY_GEN,
  3. List the mechanisms that are available for use.
    $ cryptoadm list -p
    user-level providers:
    /usr/lib/security/$ISA/pkcs11_softtoken.so: all mechanisms are enabled.
    random is enabled.
  4. Disable the mechanisms that should not be used.
    $ cryptoadm disable provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so \
    > mechanism=CKM_DES_CBC,CKM_DES_CBC_PAD,CKM_DES_ECB
  5. List the mechanisms that are available for use.
    $ cryptoadm list -p provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so
    /usr/lib/security/$ISA/pkcs11_softtoken.so: all mechanisms are enabled,
    except CKM_DES_ECB,CKM_DES_CBC_PAD,CKM_DES_CBC. random is enabled.
Example 14–18 Enabling a User-Level Software Provider Mechanism
In the following example, a disabled DES mechanism is again made available for use.
$ cryptoadm list -m provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so
$ cryptoadm enable provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so \
> mechanism=CKM_DES_ECB
except CKM_DES_CBC_PAD,CKM_DES_CBC. random is enabled.
Example 14–19 Enabling All User-Level Software Provider Mechanisms
In the following example, all mechanisms from the user-level library are enabled.
$ cryptoadm enable provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so all
random is enabled.
Example 14–20 Permanently Removing User-Level Software Provider Availability
In the following example, the libpkcs11.so.1 library is removed.
$ cryptoadm uninstall provider=/opt/SUNWconn/lib/\$ISA/libpkcs11.so.1
$ cryptoadm list
    /usr/lib/security/$ISA/pkcs11_kernel.so
kernel software providers:
