System Administration Guide: Security Services
ProcedureHow to List Available Providers
The Solaris Cryptographic Framework provides algorithms for several types of consumers:
  1. List the providers in a brief format.
    Note –
    The contents and format of the providers list varies for different Solaris releases. Run the cryptoadm list command on your system to see the providers that your system supports.
    Only those mechanisms at the user level are available for use by regular users.
    % cryptoadm list
    user-level providers:
        /usr/lib/security/$ISA/pkcs11_kernel.so
        /usr/lib/security/$ISA/pkcs11_softtoken.so
    kernel software providers:
        des
        aes
        blowfish
        arcfour
        sha1
        md5
        rsa
    kernel hardware providers:
        ncp/0
  2. List the providers and their mechanisms in the Solaris Cryptographic Framework.
    All mechanisms are listed in the following output. However, some of the listed mechanisms might be unavailable for use. To list only the mechanisms that the administrator has approved for use, see Example 14–16.
    The output is reformatted for display purposes.
    % cryptoadm list -m
    /usr/lib/security/$ISA/pkcs11_kernel.so: CKM_MD5,CKM_MD5_HMAC,
    CKM_MD5_HMAC_GENERAL,CKM_SHA_1,CKM_SHA_1_HMAC,CKM_SHA_1_HMAC_GENERAL,
    /usr/lib/security/$ISA/pkcs11_softtoken.so:
    CKM_DES_CBC,CKM_DES_CBC_PAD,CKM_DES_ECB,CKM_DES_KEY_GEN,
    CKM_DES3_CBC,CKM_DES3_CBC_PAD,CKM_DES3_ECB,CKM_DES3_KEY_GEN,
    CKM_AES_CBC,CKM_AES_CBC_PAD,CKM_AES_ECB,CKM_AES_KEY_GEN,
    des: CKM_DES_ECB,CKM_DES_CBC,CKM_DES3_ECB,CKM_DES3_CBC
    aes: CKM_AES_ECB,CKM_AES_CBC
    blowfish: CKM_BF_ECB,CKM_BF_CBC
    arcfour: CKM_RC4
    sha1: CKM_SHA_1,CKM_SHA_1_HMAC,CKM_SHA_1_HMAC_GENERAL
    md5: CKM_MD5,CKM_MD5_HMAC,CKM_MD5_HMAC_GENERAL
    rsa: CKM_RSA_PKCS,CKM_RSA_X_509,CKM_MD5_RSA_PKCS,CKM_SHA1_RSA_PKCS
    swrand: No mechanisms presented.
    ncp/0: CKM_DSA,CKM_RSA_X_509,CKM_RSA_PKCS,CKM_RSA_PKCS_KEY_PAIR_GEN,
    CKM_DH_PKCS_KEY_PAIR_GEN,CKM_DH_PKCS_DERIVE,CKM_EC_KEY_PAIR_GEN,
    CKM_ECDH1_DERIVE,CKM_ECDSA
Example 14–15 Finding the Existing Cryptographic Mechanisms
In the following example, all mechanisms that the user-level library, pkcs11_softtoken, offers are listed.
% cryptoadm list -m provider=/usr/lib/security/\$ISA/pkcs11_softtoken.so
Mechanisms:
CKM_SSL3_KEY_AND_MAC_DERIVE,CKM_TLS_KEY_AND_MAC_DERIVE
Example 14–16 Finding the Available Cryptographic Mechanisms
Policy determines which mechanisms are available for use. The administrator sets the policy. An administrator can choose to disable mechanisms from a particular provider. The -p option displays the list of mechanisms that are permitted by the policy that the administrator has set.
% cryptoadm list -p
/usr/lib/security/$ISA/pkcs11_kernel.so: all mechanisms are enabled.
random is enabled.
/usr/lib/security/$ISA/pkcs11_softtoken.so: all mechanisms are enabled.
random is enabled.
des: all mechanisms are enabled.
aes: all mechanisms are enabled.
blowfish: all mechanisms are enabled.
arcfour: all mechanisms are enabled.
sha1: all mechanisms are enabled.
md5: all mechanisms are enabled.
rsa: all mechanisms are enabled.
swrand: random is enabled.
ncp/0: all mechanisms are enabled.
