System Administration Guide: Security Services
ProcedureHow to Remove a Stash File
  1. Become superuser on the KDC that contains the stash file.
  2. Remove the stash file.
    # rm stash-file
    Where stash-file is the path to the stash file. By default, the stash file is located at /var/krb5/.k5.realm.
    Note –
    If you need to re-create the stash file, you can use the -f option of the kdb5_util command.
