System Administration Guide: Security Services
ProcedureHow to Interactively Configure a Kerberos Client
This procedure uses the kclient installation utility without a installation profile.
  1. Become superuser.
  2. Run the kclient installation script.
    You need to provide the following information:
    • Kerberos realm name
    • KDC master host name
    • Administrative principal name
    • Password for the administrative principal
Example 23–8 Running the kclient Installation Utility
The following output shows the results of running the kclient command.
client# /usr/sbin/kclient
Starting client setup
Do you want to use DNS for kerberos lookups ? [y/n]: n
        No action performed.
Enter the Kerberos realm: EXAMPLE.COM
Specify the KDC hostname for the above realm:
Setting up /etc/krb5/krb5.conf.
Enter the krb5 administrative principal to be used: clntconfig/admin
Obtaining TGT for clntconfig/admin ...
Password for clntconfig/admin@EXAMPLE.COM: <Type the password>
Do you plan on doing Kerberized nfs ? [y/n]: n
host/ entry ADDED to KDC database.
host/ entry ADDED to keytab.
Do you want to copy over the master krb5.conf file ? [y/n]: y
Enter the pathname of the file to be copied: \
Copied /net/
