System Administration Guide: Security Services
Chapter 1 Security Services (Overview)
To maintain the security of the Solaris Operating System (Solaris OS), Solaris software provides the following features:
System Security
System security ensures that the system's resources are used properly. Access controls can restrict who is permitted access to resources on the system. The Solaris OS features for system security and access control include the following:
Solaris Cryptographic Services
Cryptography is the science of encrypting and decrypting data. Cryptography is used to insure integrity, privacy, and authenticity. Integrity means that the data has not been altered. Privacy means that the data is not readable by others. Authenticity for data means that what was delivered is what was sent. User authentication means that the user has supplied one or more proofs of identity. Authentication mechanisms mathematically verify the source of the data or the proof of identity. Encryption mechanisms scramble data so that the data is not readable by a casual observer. Cryptographic services provide authentication and encryption mechanisms to applications and users.
Cryptographic algorithms use hashing, chaining, and other mathematical techniques to create ciphers that are difficult to break. Authentication mechanisms require that the sender and the receiver compute an identical number from the data. Encryption mechanisms rely on the sender and the receiver sharing information about the method of encryption. This information enables only the receiver and the sender to decrypt the message. The Solaris OS provides a centralized cryptographic framework, and provides encryption mechanisms that are tied to particular applications.
Starting in the Solaris 10 8/07 release, the Key Management Framework (KMF) provides a central utility for managing public key objects, including policy, keys, and certificates. KMF manages these objects for OpenSSL, NSS, and PKCS #11 public key technologies. See Chapter 15, Solaris Key Management Framework.
Authentication Services
Authentication is a mechanism that identifies a user or service based on predefined criteria. Authentication services range from simple name-password pairs to more elaborate challenge-response systems, such as smart cards and biometrics. Strong authentication mechanisms rely on a user supplying information that only that person knows, and a personal item that can be verified. A user name is an example of information that the person knows. A smart card or a fingerprint, for example, can be verified. The Solaris features for authentication include the following:
Authentication With Encryption
Authentication with encryption is the basis of secure communication. Authentication helps ensure that the source and the destination are the intended parties. Encryption codes the communication at the source, and decodes the communication at the destination. Encryption prevents intruders from reading any transmissions that the intruders might manage to intercept. The Solaris features for secure communication include the following:
Solaris Auditing
Auditing is a fundamental concept of system security and maintainability. Auditing is the process of examining the history of actions and events on a system to determine what happened. The history is kept in a log of what was done, when it was done, by whom, and what was affected. See Chapter 28, Solaris Auditing (Overview).
Security Policy
The phrase security policy, or policy, is used throughout this book to refer to an organization's security guidelines. Your site's security policy is the set of rules that define the sensitivity of the information that is being processed and the measures that are used to protect the information from unauthorized access. Security technologies such as Solaris Secure Shell, authentication, RBAC, authorization, privileges, and resource control provide measures to protect information.
Some security technologies also use the word policy when describing specific aspects of their implementation. For example, Solaris auditing uses audit policy options to configure some aspects of auditing policy. The following table points to glossary, man page, and information on features that use the word policy to describe specific aspects of their implementation.
Table 1–1 Use of Policy in the Solaris OS
Glossary Definition
Selected Man Pages
Further Information
audit policy
audit_control(4), audit_user(4), auditconfig(1M)
policy in the cryptographic framework
cryptoadm(1M)
Chapter 13, Solaris Cryptographic Framework (Overview)
device policy
getdevpolicy(1M)
Controlling Access to Devices
Kerberos policy
krb5.conf(4)
Chapter 25, Administering Kerberos Principals and Policies (Tasks)
network policies
ipfilter(5), ifconfig(1M), ike.config(4), ipsecconf(1M), routeadm(1M)
Part IV, IP Security, in System Administration Guide: IP Services
password policy
passwd(1), nsswitch.conf(4), crypt.conf(4), policy.conf(4)
Maintaining Login Control
policy for public key technologies
kmfcfg(1)
RBAC policy
rbac(5)
exec_attr Database
